testing DA on debian 4.0 Etch
m4ri00sh
so.... I am just reinstalling everything... and.... I get programs/dependencies missing...
- ca-certificates
- krb5-libs
- krb5-devel
...and I will add more to the list once I see it.... It is just installing...
Not sure what is going on with bind9..... but it did not install as well because some libs missing....
Just used Debian 4.0 CD1 to install base system and that is all.... for now...
Upssss I might find a reason.....
apt-get install libperl-dev gcc g++ make unzip liburi-perl libxml2-dev libstdc++5 libstdc++5-3.3-dev psmisc libextutils-autoinstall-perl
will check and update....
!!!!!!!!! And who said that it works?:confused:
DirectAdmin will now be installed on: debian 4.0
Is this correct? (must match license) (y,n) : y
beginning pre-checks, please wait...
--16:16:22-- http://files.directadmin.com/services/debian_4.0/files.sh
=> `/usr/local/directadmin/scripts/files.sh'
Resolving files.directadmin.com... 72.35.85.222
Connecting to files.directadmin.com[72.35.85.222]:80... connected.
Length: 730 [application/x-sh]
100%[================================================================================>] 730 --.--K/s
16:16:22 (6.96 MB/s) - `/usr/local/directadmin/scripts/files.sh' saved [730/730]
adding gd ...
Reading package lists... Done
Building dependency tree... Done
E: Couldn't find package gd
adding bind-utils ...
E: Couldn't find package bind-utils
adding bind ...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
bind9: Depends: libdns22 (= 1:9.3.4-2) but 1:9.3.4-2etch1 is to be installed
Depends: libisccfg1 (= 1:9.3.4-2) but 1:9.3.4-2etch1 is to be installed
Depends: libisc11 (= 1:9.3.4-2) but 1:9.3.4-2etch1 is to be installed
Depends: libisccc0 (= 1:9.3.4-2) but 1:9.3.4-2etch1 is to be installed
E: Broken packages
adding bind-libs ...
E: Couldn't find package bind-libs
ln: creating symbolic link `/etc/init.d/named' to `bind9': File exists
adding krb5-libs ...
E: Couldn't find package krb5-libs
adding krb5-devel ...
E: Couldn't find package krb5-devel
--16:16:27-- https://www.directadmin.com/
=> `/dev/null'
Resolving www.directadmin.com... 66.51.122.131
Connecting to www.directadmin.com[66.51.122.131]:443... connected.
Length: 300 [text/html]
100%[================================================================================>] 300 --.--K/s
16:16:28 (2.86 MB/s) - `/dev/null' saved [300/300]
--16:16:28-- https://www.directadmin.com/cgi-bin/daupdate?uid=3714&lid=25026
=> `/usr/local/directadmin/update.tar.gz'
Length: 4,173,324 [application/x-gzip]
100%[================================================================================>] 4,173,324 973.82K/s ETA 00:00
16:16:32 (927.51 KB/s) - `/usr/local/directadmin/update.tar.gz' saved [4173324/4173324]
*** Cannot find the named binary. Please install Bind ***
--16:16:34-- http://66.51.122.131/named.conf
=> `/etc/bind/named.conf'
Connecting to 66.51.122.131:80... connected.
Length: 887 [text/plain]
100%[================================================================================>] 887 --.--K/s
16:16:34 (8.46 MB/s) - `/etc/bind/named.conf' saved [887/887]
--16:16:34-- http://66.51.122.131/named.ca
=> `/etc/bind/named.ca'
Length: 2,769 [text/plain]
100%[================================================================================>] 2,769 --.--K/s
16:16:35 (45.52 KB/s) - `/etc/bind/named.ca' saved [2769/2769]
Installation didn't pass, halting install.
anyone? I am about to go to datacenter and reinstall the server again today ...:confused:
I can fix that for you, but it's 2:15AM here :) Maybe in the morning? Or, try to install dependencies via apt-get manually.
I tried to install those and here you go...:
what do you suggest I should do, Cause I am going nuts over here ....
s1:~# apt-get install libisccfg1
libisccfg1 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
s1:~# apt-get install libisc11
libisc11 is already the newest version.
s1:~# apt-get install libisccc0
libisccc0 is already the newest version.
s1:~# apt-get install libdns22
libdns22 is already the newest version.
s1:~# apt-get install bind-libs
s1:~# apt-get install kfb5-libs
E: Couldn't find package kfb5-libs
s1:~# apt-get install krb5-libs
s1:~# apt-get install krb5-devel
s1:~#
ok, system reinstalled.... standard base system...nothing else.... and the packages which were shown above ...
+ ssh + mc + zip + flex + bison
and I see exim was installed by default as well....without asking me .... should I uninstall it?
smtalk: so what do you suggest to do now.... do the touch /root/.custombuild and then ./setup.sh
it should work, isn't it? let me know ....
should I install anything like ca-certificates, gb or whatever....I had problem with before ...or is ./setup.sh with custombuild going to take care of it.... it seems to be funky ....
ok, system reinstalled.... standard base system...nothing else.... and the packages which were shown above ... + ssh + mc + zip + flex + bison
DA itself should uninstall exim, but you can manually remove it too:
apt-get remove exim4 exim4-base exim4-config
I never tested, first always installed DA and own apache/php system, then custombuild. Also when first time install DA to Debian Etch, install halt to wget problems ... just restart install and everything works ok (tested many times)
Not should, install script shoulds handle everything with install procedure what needed
And question, what /etc/apt/sources.list you are using ?
Ex. finnish mirrors, and WORK FINE just etch/stable, never used unstable/testing versions ...
Ok, ....... it is just compiling apache2..
1) gd .... someone needs to fix that.... everytime I run ./setup.sh it says that it is not there and fails or does whatever....
2) yes it puked on WGET.... had to run the ./setup.sh second time.....
3) this time I saw it got to the point when the scripts checks for existence of /root/.custombuild ....
so it is going and ...going .... will update after a second....
Ok, did a screenshot when it complained...
Zoner... good call... thank you
OK, I was able to install it... DA works .....
you might need to remember about ..... post ala custombuild thing ....
./build rewrite_confs
other than that..... I am logged into DA and trying to configure everything...
thank you all... :):D hard two days ....but we could do it :)
