BUG? (/etc/httpd/conf/extra/directadmin-vhosts.conf)
m4ri00sh
It looks like that when I delete user thru DA it does not delete the entry for the user in the : /etc/httpd/conf/extra/directadmin-vhosts.conf
and APACHE stops... when I tried to start it manually I get this:
s1:~# /etc/init.d/httpd start
Starting httpd: httpd: Syntax error on line 155 of /etc/httpd/conf/httpd.conf: Syntax error on line 3 of /etc/httpd/conf/extra/directadmin-vhosts.conf: Could not open configuration file /usr/local/directadmin/data/users/gen/httpd.conf: No such file or directory
Once I edited the file and delete it (the line pointing to not existing configuration file) manually my apache2.2 starts... and everything is fine....
I am using Debian... with Apache2.2 and installed that with help of custombuild...
any other questions? :)
Not a bug :) Do you have "/etc/httpd/conf/extra/directadmin-vhosts.conf" in /usr/local/directadmin/conf/directadmin.conf ? If yes - you probably need to email DirectAdmin support.
No, I don't have the line in the conf file..... and .... ?? :)
Does it mean, I don't have to contact DA support :):D
If you don't have it - you need to add it :) (change /etc/httpd/conf/httpd.conf with it)
but how should I add it.... is there any variable like .... "vhosts"... so it looked like
vhosts=/etc/httpd/conf/extra/directadmin-vhosts.conf
hmmmmm?
and what do you mean by ....
I have in my /etc/httpd/conf/httpd.conf line with....
Include conf/extra/directadmin-vhosts.conf
hmmmm?
I DON'T have
but I DO have:
Include conf/extra/directadmin-vhosts.conf in /etc/httpd/conf/httpd.conf
You got me confused :)
cause by having ....
apacheconf=/etc/httpd/conf/httpd.confin /usr/local/directadmin/conf/directadmin.conf
it is all tha same ....
Change:
[COLOR=Black]apacheconf=/etc/httpd/conf/httpd.conf[/COLOR]
To:
[COLOR=Black]apacheconf=[/COLOR]/etc/httpd/conf/extra/directadmin-vhosts.conf
In /usr/local/directadmin/conf/directadmin.conf
yeah, but then it will not read all OTHER .conf files at all.... wow
EDITED:
OK, now I know how that works :)
I hope DA Support will show up soon.... that is kind of interesting.... what needs to be in the /usr/local/directadmin/conf/directadmin.conf.... and how it really reads/updates configs....
If you're using custombuild, which by the fact that directadmin-vhosts.conf is mentioned, I will assume to be true, then ensure you've got a few things.
1) if you type the following, you should get the same output:
[root@server]# [b]/usr/local/directadmin/directadmin c | grep apacheconf[/b]
apacheconf=/etc/httpd/conf/extra/directadmin-vhosts.conf
[root@server]#
If you don't, then add:
to the /usr/local/directadmin/conf/directadmin.conf file.
Save, and restart DA. Type the above command again to ensure you get the correct value. (sometimes a blank line has to be added to the bottom of the directadmin.conf if it's not finding it)
Do not go on until this step is satisfied and you get the correct output.
2) once that's all good and done, type the following to make sure you're using the correct main /etc/httpd/conf/httpd.conf file
grep directadmin-vhosts.conf /etc/httpd/conf/httpd.conf
If it's correct, you'll get:
Include /etc/httpd/conf/extra/directadmin-vhosts.conf
as output. If not, you'll get nothing in the output.
So, if you don't have the correct /etc/httpd/conf/httpd.conf file, simply type:
./build rewrite_confs
which will redo the works for you, including resetting the directadmin-vhosts.conf file, and restting the main httpd.conf file to be correct.
