SupermanInNY
- Sep 28, 2004
[RESOLVED! - see below]
Hi All,
I tried to use PEAR with Mail.php to enforce better outgoing email management.
PEAR seems simple enough to use, stick a 'require_once' statement and then provide the handshake info (server, account name and password) along with the header, body strings/arrays.
However,. I'm getting errors running the scripts and I don't how to overcome it. I'm stuck on safe_mode limitations or on undeclared functions:
Fatal error: Call to undefined function: send()
<?php
require_once "Mail.php";
$from = "Sandra Sender <[email protected]>";
$to = "Ramona Recipient <[email protected]>";
$subject = "Hi!";
$body = "Hi,\n\nHow are you?";
$host = "mail.DDDDD.com";
$username = "[email protected]";
$password = "DDDDDD";
$headers = array ('From' => $from,
'To' => $to,
'Subject' => $subject);
$smtp = Mail::factory('smtp',
array ('host' => $host,
'auth' => true,
'username' => $username,
'password' => $password));
$mail = $smtp->send($to, $headers, $body);
if (PEAR::isError($mail)) {
echo("<p>" . $mail->getMessage() . "</p>");
} else {
echo("<p>Message successfully sent!</p>");
This is the line it fails on:
send() is part of the PEAR thingy, but I can't get it to work!
Any pointers?
Yes, I installed PEAR (to the best of my knowledge), but please shed some light on how to check that the install is correct?
Thanks,
-Alon
RESOLVED - HOW TO:
Step 1:
Make sure that your PHP compile has pear included in it:
--with-pear \
Step 2:
Get to know what you need and already have in pear
at the commandline type:
pear list
this will display to you what extentions/packages you already have installed with pear.
This is what I have on my server
Installed packages, channel pear.php.net:
Package Version State
Archive_Tar 1.3.2 stable
Console_Getopt 1.2.2 stable
HTML_Template_IT 1.2.1 stable
Mail 1.1.14 stable
Mail_Mime 1.4.0 stable
Net_SMTP 1.2.10 stable
Net_Socket 1.0.8 stable
Net_UserAgent_Detect 2.3.0 stable
PEAR 1.5.4 stable
Structures_Graph 1.0.2 stable
And it worked, so you might want to have a similar settings.
Step 3:
OK.. chances are that you might not have all that I have. So,. install it.
(how???)
Luckily it is not complicated
We need to make a small deviation from the straight install.
run the following:
updatedb
locate php.ini
vi /nano /pico php.ini
put a ; (semi-colon) at the begining of the disable_functions so that it will be commented out.
service httpd restart
NOW lets continue with the PEAR installation:
pear install mail
Will install the Mail package.
I don't know why I'm having problems with the connection to the mirror sites, so instead, you can download the tgz files and install them the same way.
For instance:
wget -c http://download.pear.php.net/package/PEAR-1.5.4.tgz
Will get you the file to your server.
Then run:
pear install PEAR-1.5.4.tgz
that's it. It is the same as typing the
pear install pear
Notice that as I'm writting this How-To, there is a msg on Pear's website that 1.6.0 is due out in 5 days.
BUT HEY... I GOT AN ERROR TYPING:
OK.. it is very likely that you already have some parts of PEAR installed (by default),.so you can't install the same package.
But you can UPGRADE it.
pear upgrade PEAR-1.5.4.tgz
Very simple and it runs in two seconds.
Next package that you need to install is:
pear install Net_SMTP
Other package might also be needed,. but you have the list of packages that I have installed on my server and it is working for me.
Step 4:
Are we done yet?
Nope.. almost.
Remember in the previous step, you commented out the disable_functions, you need to UNcomment them so you are back to the security level you were before.
BUT DON'T EXIT THE php.ini yet:
You need to add one more thing:
You have a section that has:
safe_mode_include_dir =
and it is likely to be empty.
Populate it with:
safe_mode_include_dir = /usr/local/lib/php/
NOW save and exit php.ini
DONE!
Hi All,
<?php
$subject = "Hi!";
'To' => $to,
'auth' => true,
} else {
Any pointers?
Thanks,
-Alon
RESOLVED - HOW TO:
Step 1:
--with-pear \
Step 2:
pear list
Mail 1.1.14 stable
PEAR 1.5.4 stable
Step 3:
(how???)
run the following:
updatedb
locate php.ini
pear install mail
For instance:
Then run:
pear install pear
Step 4:
Are we done yet?
Nope.. almost.
Populate it with:
DONE!
