retry timeout error?
rldev
I have a user who is seeing the following bouncebacks when trying to send email to her account from an outside account:
Begin forwarded message:
> From: Mail Delivery System <[email protected]>
> Date: August 28, 2007 11:58:26 AM EDT
> To: [email protected]
> Subject: Mail delivery failed: returning message to sender
> This message was created automatically by mail delivery software.
> A message that you sent could not be delivered to one or more of its
> recipients. This is a permanent error. The following address(es) failed:
> save to /home/milbot/imap/milbot.com/lisa/Maildir/.INBOX.spam/new/
> generated by [email protected]
> retry timeout exceeded
I have Googled this error, but I can't hone in on the problem.
Perhaps the mailbox is full? Or has the wrong permissions?
Otherwise it's going to require logging in and testing to figure it out.
Neither is true. Permissions are fine and the mailbox is not full.
Find the log entries for the problem emails; they should give you more detail.
Hi Jeff,
Would I be looking at the exim main log? I see nothing in the rejectlog.
It is a permissions error after all. I was told that the permissions for:
/home/milbot/imap/milbot.com/janet/Maildir/.INBOX.spam/new needed to be
drwxrwx---
and not
drwxr-xr-x
so that the group "mail" could write to the file. Is this the case? If so, how do fix these permissions server wide? and why would they suddenly be incorrect?
Hey,
You may want to take a look at the "set_permissions.sh" script located in the /usr/local/directadmin/scripts" directory.
That may help you.
David
Hey,
That may help you.
David
That will set dovecot permissions? I will try to read up on it.
Yep, the mainlog.
If the set_permissions.sh script doesn't work you can create a script to make all the changes at once.
