UpAllNight
- May 23, 2005
After enabling spam assassin in exim.conf (spamblocker 2.1.1) and following Jeff's directions, some test incoming mail is failing as in this example which I sent from a gmail account to a working email account hosted on the server.
1IfLZn-0003hs-2O <= [email protected] H=nf-out-0910.google.com [64.233.182.190] P=esmtp S=1990 [email protected] T="Hi David" from <[email protected]> for [email protected]
1IfLZn-0003hs-2O <[email protected]>: spamcheck transport output: An error was detected while processing a file of BSMTP input.
1IfLZn-0003hs-2O ** [email protected] F=<[email protected]> R=spamcheck_director T=spamcheck: Child process of spamcheck transport returned 2 from command: /usr/sbin/exim (preceded by transport filter timeout while writing to pipe)
1IfLed-0003vC-8k <= <> R=1IfLZn-0003hs-2O U=mail P=local S=3282 T="Mail delivery failed: returning message to sender" from <> for [email protected]
1IfLZn-0003hs-2O Completed
when I run this command:
# /usr/bin/spamd -d -c -m 5
it returns:
[18743] warn: server socket setup failed, retry 1: spamd: could not create INET socket on 127.0.0.1:783: Address already in use
[18743] warn: server socket setup failed, retry 2: spamd: could not create INET socket on 127.0.0.1:783: Address already in use
[18743] error: spamd: could not create INET socket on 127.0.0.1:783: Address already in use
Anyone have any ideas as to where I should start looking for the problem?
Thanks,
David
it returns:
Thanks,
David
