Possible Bug in RoundCube?
I've owned a DA license for the past 6 months and despite it's shortcomings it's pretty good bang for your buck..
I also know that DA may put this issue on the back burner because it could very well be a problem that is being caused by RoundCube as it's 3rd party software... LOL
In any event I have a feeling there is a problem with RoundCube and I'm not sure how to correct it orrrrrrrr it may also be a glitch with the way DA handles email forwarding if in fact it does...
I have quite a few sites that are using less than 5 MB of disc space but I have one that is using up 95% of the 100MB that has been allocated to her because of stored emails.
Problem is, the email addresses that she is using are being forwarded to an address that the site owners ISP has created for her, BUT, Roundcube stores the forwarded mail in its database for some reason...
One would think that all forwarded mail to an outside resource would bypass the default email program on the server completely. But it appears that it doesn't.
So now the other issue.. RoundCube is a SLUG!!!.... When logging in, it tries to upload all the emails that it has stored in the program PRIOR to allowing you access inside. I have one site that has 1622 emails stored in there and here I sit waiting for the software to open while it attempts to preload all the emails... (I can see the counter just a spinning in the bottom left hand corner of the screen)..
Now I want to try to delete all the duplicated garbage that is being stored... I select to delete 200 emails at a time.. I wait about 15 seconds while the emails are being selected.. I now want to move them to the trash bin.. I wait about 60 seconds while they get transferred into the trash bin.. Once transferred, I try to select another 200 emails to send to trash.. Cannot do it.. The page remains blank...
Now I go to the Trash bin and wait 30 seconds while it loads up.. I select all and wait another 10 seconds.. I hit delete and wait about 30 seconds while the 200 hundred emails get dumped..
Then I go back to the Inbox and start the process all over again..
It has now been 20 minutes and I still have 162 emails to delete..
Totally NOT impressed with this software at all...
Anybody got any ideas how DA can bypass the Default email program when forwarding mail to an outside resource????
Ed
Ed
