mod_rewrite
comicway
i've got a problem with url rewriting, i've tried this in a .htaccess:
RewriteEngine on
RewriteRule ^([a-zA-Z]+)\.html$ index.php?page=$1 [L]
to modify url like www.mydomain.com/index.php?page=test
to www.mydomain.com/test.html
but this is not working,
i've check with phpinfo if the module mod_rewrite is present and activate and i've got this:
Loaded Modules 	core mod_access mod_auth mod_include mod_log_config mod_env mod_setenvif mod_ssl prefork http_core mod_mime mod_status mod_autoindex mod_asis mod_suexec mod_cgi mod_negotiation mod_dir mod_imap mod_actions mod_userdir mod_alias mod_rewrite mod_so sapi_apache2
but in my httpd.conf i didn't find any LoadModule with mod_rewrite.so
i've also searching in my server to mod_rewrite.so and i didn't find anything.
Can you help me?
cris
Could you post the result of teh following command:
grep mod_rewrite /etc/httpd/conf/httpd.conf
Also, what DA version are you using?
box101:/# grep mod_rewrite /etc/httpd/conf/httpd.conf
box101:/#
DirectAdmin v1.30.2
I am really not sure why it's not there, but any way try the following:
1. Check that mod_rewrite module is available:
ls -la /etc/httpd/modules/mod_rewrite.so
2. Backup the current httpd.conf file, just in case:
mv -i /etc/httpd/conf/httpd.conf /etc/httpd/conf/httpd.conf-`date +%d-%b-%Y`
cp /etc/httpd/conf/httpd.conf-`date +%d-%b-%Y` /etc/httpd/conf/httpd.conf
3. Edit httpd.conf as follows:
a) add
LoadModule rewrite_module modules/mod_rewrite.so
after
LoadModule alias_module modules/mod_alias.so
b) add
AddModule mod_rewrite.c
after
AddModule mod_alias.c
c) Find the following line
<Directory /home/*>
and add
AllowOverride All
4. Restart Apache
service httpd restart
Let us know how it goes!
All the above assumes RH/Centos Linux and Apache 1.3.x
box101:/# ls -la /etc/httpd/modules/mod_rewrite.so
ls: /etc/httpd/modules/mod_rewrite.so: No such file or directory
Can you tell me where i can find mod_rewrite.so and mod_rewrite.c?
Thanks in advance
Thanks in advance
It looks like there is something wrong with your Apache installation.
mod_rewrite module should be built as part of Apache build made by DA.
i've only update apache to 2.0
how i can reinstall apache 2.0 with mod-rewrite
cris?
