Where do .sql files go with System Backup
polo
I just recently did a full system backup. I need to grab the .sql files out of one omy users so I can manually upload them. Where does DA store the .sql files when doing a full system backup ?
Chris
I don't know offhand, and I don't have the time to look just now, but I do know you can unpack the backup using either "tar" on your server, or "winzip" or other unzipping program on a Windows computer, and you can look for it yourself.
How do I submit this as a bug, I have done system backup several times with sql db's checked. They are no where to be found.
Chris
Chris
DA creates a "mysql" folder in which the databases are stored as "username.sql.tar.gz" for each user name. This of course assumes that Backup MySQL Databases was ticked under Configure Full System Backup.
It was ticked. there is no mysql folder in username.sql.tar.gz" it only does it if i backup the users individually, I'm pretty sure its a bug.
Chris
