child pid * exit signal Segmentation fault (11)
walleed222
hi
I downgrade from apache 2.2 to 1.3 and many sites not working(spicial which contain VB ) when I check the httpd logs I find continues
yes I did them , now I have very strange issue , every site have NUKe not open I try many thing and it is same ,can any one help me about that
I isolate the problem , any page use any zlib function will crach and not open , I try to rebuild it many time and the same and try pther version and same it is very strange problem , I now waiting directadmin support response , any suggest?
Did you do ./build clean
And then do a rebuild.
yes I do that many times , it is just need rebuild PHP and change the configuration in config.php and remove some lines from there
the last news is , I need gd and when I rebuild PHP with gd the problem appear again , I need gd now but I can´t install it
hi , it is solved now it was png lib problem the old version was 1.2.18 I changed it in build script to 1.2.23 and rebuild php and restart apache and every thing work nice , I am not sure if the 1.2.18 has some bug but perhaps my files was corrupted
