WGET problem
DoubleUare
Hello All,
I've got a problem with WGET...
Problem:
f8:/home/manageuser/install# wget ftp://*username*:*password*@gamepackages.redirectspace.nl/public_html/cod2_20-11-2007.tar
--14:23:58--  ftp://*username*:*password*@gamepackages.redirectspace.nl/public_html/cod2_20-11-2007.tar
=> `cod2_20-11-2007.tar'
Resolving gamepackages.redirectspace.nl... 84.243.254.126 Connecting to gamepackages.redirectspace.nl[84.243.254.126]:21... connected.
Logging in as *username* ... Logged in!
==> SYST ... done.    ==> PWD ... done.
==> TYPE I ... done.  ==> CWD /public_html ... done.
==> PASV ... done.    ==> RETR cod2_20-11-2007.tar ... done.
Length: -603,375,616 (unauthoritative)
    [                              <=>   ] -603,375,616   11.27M/s
wget: retr.c:292: calc_rate: Assertion `bytes >= 0' failed.
Aborted
Some how it stops downloading when files are bigger than 3GB, it can't calculate the real package size.
I enabled Large File Support (LFS) at the kernel, but that did not work aswell.
System Info/OS:
CentOS, Intel Pentium D CPU 2.80GHz, 1024MB RAM
DirectAdmin v1.31.1
ProFTPd 1.2.10
PHP5
Can somebody please help me?
Rogier
NL
that's odd. I just wget a 26G file couple days ago without any problem.
Aborted
What is the current wget version on your server? Make sure you have the latest version of wget v1.10 or higher. Older version(s) of wget can not handle a file larger than 2GB.
wget
Version info: GNU Wget 1.10.2
The wget problem isn't solved, but somehow it doesn't calculates files.
It is a little strange, but when the download is at 2GB the calculated size turns to a minus ( - ) numbercount. It still downloads the file the whole file, maybe a linux kernel problem...
So not solved... but also not a big problem... It works... strange... :confused:
May I suggest asking the question on the centos-users email list, since it's a CentOS problem and not a DirectAdmin problem?
