php problems
Newbie
I just got host with recently installed DirectAdmin. I'm 1st time useing DirectAdmin so it's new for me. When I logined in DirectAdmin I saw an error
"cannot find file: /usr/local/bin/php" how can I fix it?
It seems like your installation is not complete...
You can try to build PHP yourself by logging into your server as root using SSH and going to /usr/local/directadmin/customapache and running
./build clean
./build php
Then restart apache and see if the problem still exists.
Regards,
./build clean
./build php
Regards,
what does command ./build clean do? Will it clean up my server? or delete directadmin files?
There is no /usr/local/directadmin/customapache directory.
There're conf/, custombuild/, data/ and scripts/ folders in /usr/local/directadmin/ directory
Add:
looks like it working now, should I resetup my DNS/email/ftp settings in DirectAdmin after I made
./build clean
./build php
Then you must have a newer version than me ;) Try the custombuild/ directory...
./build clean
removes all the downloaded files that the build application uses to build PHP and other things.
