ircman
Hi!,
Seems that the downloadlink is dead. Is the latest version somewhere else available ?
Thanks,
Thanks,
gosh.. i need a awstate report by e-mail!!![]()
Warning: Can't find language files for "en". English will be used.
Warning: Can't read file "status_http.pm" (status http detection will not work correctly).
Check if file is in "./lib" directory and is readable.
Warning: Can't read file "search_engines.pm" (search engines detection will not work correctly).
Warning: Can't read file "domains.pm" (domains detection will not work correctly).
Warning: Can't read file "operating_systems.pm" (operating systems detection will not work correctly).
Warning: Can't read file "robots.pm" (robots detection will not work correctly).
Warning: Can't read file "browsers.pm" (browsers detection will not work correctly).
Warning: Can't read file "mime.pm" (mime detection will not work correctly).
cant beleive their aint any official word on how to solve this yet. even my best mate google doesnt have a solution.
I've installed this plugin, and have a problem at http://obelix.it2go-obelix.net:2222/CMD_PLUGINS_ADMIN/awstats
Warning: file_get_contents(): SAFE MODE Restriction in effect. The script whose uid is 107 is not allowed to access /etc/passwd owned by uid 0 in /usr/local/directadmin/plugins/awstats/admin/index.html on line 39 Warning: file_get_contents(/etc/passwd): failed to open stream: Invalid argument in /usr/local/directadmin/plugins/awstats/admin/index.html on line 39 Couldn't determine user standardly!
Warning: file_get_contents(): SAFE MODE Restriction in effect. The script whose uid is 106 is not allowed to access /etc/passwd owned by uid 0 in /usr/local/directadmin/plugins/awstats/admin/index.html on line 39 Warning: file_get_contents(/etc/passwd): failed to open stream: Inappropriate ioctl for device in /usr/local/directadmin/plugins/awstats/admin/index.html on line 39 Couldn't determine user standardly!
Select the users that can access the Awstats Plugin:
Error: Couldn't open config file "awstats.server02.xsxn.nl.conf" nor "awstats.conf" after searching in path "/home/advocaat44/public_html/awstats,/etc/awstats,/usr/local/etc/awstats,/etc,/etc/opt/awstats": No such file or directory
- Did you use the correct URL ?
Example: http://localhost/awstats/awstats.pl?config=mysite
Example: http://127.0.0.1/cgi-bin/awstats.pl?config=mysite
- Did you create your config file 'awstats.server02.xsxn.nl.conf' ?
If not, you can run "awstats_configure.pl" from command line, or create it manually.
Check config file, permissions and AWStats documentation (in 'docs' directory).
I have the same problem..
Recently moved to a new server. On the old one everything worked fine. Now on the new one we also upgraded apache, php & mysql tot newer version using custombuild. Safemode is off as default, so that must not be the problem altho it saying SAFE MODE restriction in effect.
I just checked and it`s off...
Anybody got an idea? Maybe suPHP or any other rights problem. I set just as a test the user to diradmin:diradmin on /etc/passwd and then its working. So its something in the rights thing.
