[tools] update.script
Do you like use update.script ?
  • yes, all time
    Votes: 221 69.1%
  • no, some time
    Votes: 44 13.8%
  • some time
    Votes: 55 17.2%
  • Total voters
    320
./update.script
Shows only heading:
# GNU GENERAL PUBLIC LICENSE
# Version 2, June 1991
................................................................... etc.
More nothing occurs :confused:
Have you tried:
./update.script CLEAN
./update.script
./update.script
Shows only heading:
Have you tried:
./update.script
Yes, I tried, but it not change anything..
I see only script head and must make CTRL+C for return in shell.
Wael,
Im getting strange errors on upgrading phpmyadmin.
HTTP request sent, awaiting response... 404 Not Found
20:51:46 ERROR 404: Not Found.
Catastrophe! All Mirrors failed.
Is sourceforge down?
Wael,
there seems to be problem with phpmyadmin mirrors... you should try after some time... it took me atleast 10 tries ... before i finally got slow mirror...
AVG Anti-Virus
I trying to make a cron job to make this work every Sunday .
avgscan -clean -ext=* -rt -arc /home
is OK the way I did it ?
check picture
or there is another way I can make this happen ?
thanks for any help
check picture
thanks for any help
You will need the full path to the avgscan command too.
MRTG script fails as it is missing a step:
The script has a 'cleanup' process that deletes stuff from /tmp
But the next step attempts to Untar at the /usr/local/updatescript.
The missing step is the
cd /usr/local/updatescript
that gets you back to the working directory where you actually d/l the mrtg file.
without going back, the script attempts to find the ./configure line where it can't find it (as the pointer was left at the /tmp).
Here is the correct code fix:
rm -rf mrtg*
echo "Preparations complete..."
cd /tmp ; rm -fr mrtg*.tar.gz mrtg*
echo "Downloading the most recent MRTG and installing it..."
OH.. and I just love that script :))
-Alon.
When i try to install mod_security (Apache 2) ii got the folowing error:
./update.script: line 1092: ./updatescript: No such file or directory
i donated for this script in 2 - 3 month past
but now i make new system new os
now i use FreeBSD 6.2
when
./update.scripts MRTG
found
Checking for previous MRTG installation...
The directory /var/www/html/mrtg does not exist. I will create it...
Creating necessary directories and preparing for installation...
cd: can't cd to /usr/local/src
--14:29:06-- http://oss.oetiker.ch/mrtg/pub/mrtg-2.15.2.tar.gz
=> `mrtg-2.15.2.tar.gz'
Resolving oss.oetiker.ch... 213.144.138.195
Connecting to oss.oetiker.ch|213.144.138.195|:80... connected.
Length: 1,070,900 (1.0M) [application/x-tar]
100%[======================================================================================>] 1,070,900 221.57K/s ETA 00:00
14:29:12 (193.76 KB/s) - `mrtg-2.15.2.tar.gz' saved [1070900/1070900]
cd: too many arguments
./update.script: ./configure: not found
make: no target to make.
make: don't know how to make install. Stop
MRTG has been installed...
Updating MRTG config and template...
--14:29:12-- http://tools.supernamechange.com/mrtgcfg.tar.gz
=> `mrtgcfg.tar.gz'
Resolving tools.supernamechange.com... 72.55.156.182
Connecting to tools.supernamechange.com|72.55.156.182|:80... connected.
Length: 2,056 (2.0K) [application/x-gzip]
100%[======================================================================================>] 2,056 --.--K/s
14:29:13 (5.01 MB/s) - `mrtgcfg.tar.gz' saved [2056/2056]
Adding MRTG to /etc/crontab...
env: /usr/local/mrtg-2/bin/mrtg: No such file or directory
Cleaning up installation...
MRTG install done
how to fix it
IMAP
Apache 1
nano -w  configure.php
Apache 2
nano -w  configure2.php
add
--with-imap=/usr/local/imap-2004c1 \
after
--with-zip \
save then build php and restart apache
service httpd restart
AVG Anti-Virus
Clean folder HOME (full)
clean folder HOME (without archives)
avgscan -clean -ext=* -rt /home
ill add more soon.
Best Regards,
Wael Isa
[/FONT]
I'm trying to install php-imap. However, a yum install php-imap tells me there's nothing to do, so i'm trying this.
I'm using apache 1.x, but i'm a little confused. Where is the configure.php am i supposed to build? I randomized and found configure.php4 under directadmin's custombuild apache, not sure whether its correct. if so, i don't find with-zip though.
Also, what is the proper way to build php?
in
/usr/local/directadmin/customapache
configure.php = apache 1x
configure2.php = apache 2x
or
/usr/local/directadmin/custombuild/configure
ap1 = apache 1x
ap2 = apache 2x
Wael
MODsecurity 2.1.4 Apache 2.2.6 & custombuild ONLY
if you want other apache ver, post in reply to add in next update.
Wael
