dovecot - starting failed via DA, not with ssh
AxlF
I just installed DA. From the first login I got a message that dovecot is down.
This message has been automatically generated notifying you that the service dovecot is currently down.
If I try to start it via "Service Monitor" it says "dovecot stopped".On clicking "restart":
An error has occurred
Details
if I start dovecot on console there are no errors, and dovecot is starting!
Could this be a bug?
Regards,
Alexander
You don't tell us what OS Distribution you're running so it's a bit hard to help you figure it out. Perhaps DirectAdmin is trying to start it incorrectly.
Have you tested to see if it's actually running when DirectAdmin says it isn't:
$ ps waux | grep ovecot
Jef
Jef
Sorry.
I'm using Debian etch...
$ ps waux | grep dovecot
No results after restarting dovecot with DA.
Manually on console:
$ /etc/init.d/dovecot restart
Shutting down dovecot:
Starting dovecot:
root 30243 0.0 0.0 1924 588 ? Ss 04:27 0:00 dovecot
root 30244 0.0 0.0 2236 912 ? S 04:27 0:00 dovecot-auth
dovecot 30246 0.0 0.0 3300 1488 ? S 04:27 0:00 pop3-login
dovecot 30247 0.0 0.0 3300 1488 ? S 04:27 0:00 pop3-login
dovecot 30248 0.0 0.0 3300 1488 ? S 04:27 0:00 pop3-login
dovecot 30249 0.0 0.0 3300 1488 ? S 04:27 0:00 pop3-login
Where to search the answer?
Any errors in /var/log/directadmin/error.log
No, not in error.log
But in errortask.log
007:12:21-04:27:01: service dovecot wasn't running, starting it
2007:12:21-04:27:01: Error starting service dovecot : uid 0 gid 0 : /etc/init.d/dovecot start                           >>/dev/null 2>>/dev/null
2007:12:21-04:27:11: service dovecot didn't start, re-starting it
2007:12:21-04:27:12: Error restarting service dovecot : uid 0 gid 0 : /etc/init.d/dovecot restart                           >>/dev/null 2>>/dev/null
The only difference I can think of would be the $PATH evironmental variable.
Try editing:
/etc/init.d/dovecot
in the start) section, change:
dovecot
to
/usr/sbin/dovecot
