Dauser2007
- Dec 5, 2007
how to uninstall exim on server ?
thanks
thanks
# SpamBlocker.exim.conf.2.1.1-release #
# 05-Jun-2007 #
# Runtime configuration file for DirectAdmin/Exim 4.24 and above #
# Requires exim.pl dated 20-Apr-2007 17:09 or later #
######### IMPORTANT ########## IMPORTANT ########## IMPORTANT ########
# WARNING! Be sure to back up your previous exim.conf file before #
# attempting to use this exim.conf file. #
# Do may not use this exim.conf Exim configuration file unless you #
# make the required modifications to your Exim configuration #
# following the instructions in the README file included in this #
# distribution. #
# This is version "2.0 of the SpamBlocker exim.conf file as #
# distributed by NoBaloney Internet Services for DirectAdmin based #
# servers. #
# More information about NoBaloney.net may be found at: #
# http://www.nobaloney.net/ #
# More information about DirectAdmin may be found at: #
# http://www.directadmin.com/ #
# This Exim configuration file has been modified from the original #
# as distributed with Exim 4. The modifications have been made by: #
# Jeff Lasman #
# NoBaloney Internet Services #
# Post Office Box 52200 #
# Riverside, CA 92517-3200 #
# [email protected] #
# (951) 643-5345 #
# The SpamBlocker exim.conf file has been modified from the original #
# exim.conf file as distributed with Exim 4, which includes the #
# following copyright notice: #
# Copyright (C) 2002 University of Cambridge, Cambridge, UK #
# Portions of the file are taken from the exim.conf file as #
# distributed with DirectAdmin (http://www.directadmin.com/), #
# Copyright(C)2003-2007 JBMC Software, St Albert, AB, Canada T8N 5C9 #
# Portions of this file are written by Jeff Lasman, of #
# NoBaloney Internet Services and are copyright as follows: #
# Copyright (C) 2004-2007 NoBaloney Internet Services, #
# Riverside, Calif., USA #
# The entire Exim 4 distribution, including the exim.conf file, is #
# distributed under the GNU GENERAL PUBLIC LICENSE, Version 2, #
# June 1991. If you do not have a copy of the GNU GENERAL #
# PUBLIC LICENSE you may download it, in it's entirety, from #
# the website at: #
# http://www.nobaloney.net/exim/gnu-gpl-v2.txt #
# The most recent version of this SpamBlocker exim.conf file may #
# always be downloaded from the website at #
# http://www.nobaloney.net/exim/exim.conf.spamblocked #
# Whenever you change Exim's configuration file, you *must* remember #
# to HUP the Exim daemon, because it will not pick up the new #
# configuration until you do. However, any other Exim processes that #
# are started, for example, a process started by an MUA in order to #
# send a message, will see the new configuration as soon as it is in #
# place. #
# You do not need to HUP the daemon for changes in auxiliary files #
# that are referenced from this file. They are read every time they #
# are used. #
# It is usually a good idea to test a new configuration for #
# syntactic correctness before installing it (for example, by #
# running the command "exim -C /config/file.new -bV"). #
### MODIFICATION INSTRUCTIONS ########## MODIFICATION INSTRUCTIONS ###
# YOU MUST MAKE THE CHANGES TO THIS SpamBlocked exim.conf file as #
# documented in the README file. #
# The README file for this version is named: #
# README.SpamBlocker.exim.conf.2.1 #
# update information: changed blockists 29-May-2007 version 2.1 #
# Specify your host's canonical name here. This should normally be the
# fully qualified "official" name of your host. If this option is not
# set, the uname() function is called to obtain the name. In many cases
# this does the right thing and you need not set anything explicitly.
# primary_hostname =
# Specify the domain you want to be added to all unqualified addresses
# here. An unqualified address is one that does not contain an "@" character
# followed by a domain. For example, "[email protected]" is a fully qualified
# address, but the string "caesar" (i.e. just a login name) is an unqualified
# email address. Unqualified addresses are accepted only from local callers by
# default. See the receiver_unqualified_{hosts,nets} options if you want
# to permit unqualified addresses from remote sources. If this option is
# not set, the primary_hostname value is used for qualification.
# qualify_domain =
# If you want unqualified recipient addresses to be qualified with a different
# domain to unqualified sender addresses, specify the recipient domain here.
# If this option is not set, the qualify_domain value is used.
# qualify_recipient =
# the next line is required to start the smtp auth script included
# in DirectAdmin
perl_startup = do '/etc/exim.pl'
# the next line is required to start the system_filter included in
# DirectAdmin to refuse potentiallly harmful payloads in
# email messages
system_filter = /etc/system_filter.exim
# next line to allow incoming email submission port 587
# see also check_recipient second ruleset
daemon_smtp_ports = 25 : 587
# SET SOME MEANINGFUL LIMITS
# OPTIONAL MODIFICATIONS:
# These defaults work for us; you may wish to modify them
# for your environment
message_size_limit = 20M
smtp_receive_timeout = 5m
smtp_accept_max = 100
message_body_visible = 3000
print_topbitchars = true
# ALLOW UNDERSCORE IN EMAIL DOMAIN NAME
# domains shouldn't use the underscore character "_" but some
# may. Because John Postel, one of the architects of the Internet,
# said "Be liberal in what you accept and conservative in what you
# transmit, we choose to allow underscore in email domain names so we
# can receive email form domains which use the underscore character
# in their domain name.
helo_allow_chars = _
# CHANGE LOGGING BEHAVIOR # We weren't happy with the default Exim logging behavior through # syslog; it didn't give us enough information. So we turned off
# syslog behavior and changed the logging behavior to give us what we
# felt was more helpful information. You may choose to delete or modify
# this section.
log_selector = \
+delivery_size \
+sender_on_delivery \
+received_recipients \
+received_sender \
+smtp_confirmation \
+subject \
+smtp_incomplete_transaction \
-dnslist_defer \
-host_lookup_failed \
-queue_run \
-rejected_header \
-retry_defer \
-skip_delivery
syslog_duplication = false
# These options specify the Access Control Lists (ACLs) that
# are used for incoming SMTP messages - after the RCPT and DATA
# commands, respectively.
acl_smtp_rcpt = check_recipient
acl_smtp_data = check_message
# define local lists
addresslist whitelist_senders = lsearch;/etc/virtual/whitelist_senders
addresslist blacklist_senders = lsearch;/etc/virtual/blacklist_senders
domainlist blacklist_domains = lsearch;/etc/virtual/blacklist_domains
domainlist whitelist_domains = lsearch;/etc/virtual/whitelist_domains
domainlist local_domains = lsearch;/etc/virtual/domains
domainlist relay_domains = lsearch;/etc/virtual/domains : localhost
domainlist use_rbl_domains = lsearch;/etc/virtual/use_rbl_domains
hostlist auth_relay_hosts = *
hostlist bad_sender_hosts = lsearch;/etc/virtual/bad_sender_hosts
hostlist bad_sender_hosts_ip = net-lsearch;/etc/virtual/bad_sender_hosts
hostlist relay_hosts = net-lsearch;/etc/virtual/pophosts : 127.0.0.1
hostlist whitelist_hosts = lsearch;/etc/virtual/whitelist_hosts
hostlist whitelist_hosts_ip = net-lsearch;/etc/virtual/whitelist_hosts
# If you want to accept mail addressed to your host's literal IP address, for
# example, mail addressed to "user@[111.111.111.111]", then uncomment the
# following line, or supply the literal domain(s) as part of "local_domains"
# above. You also need to comment "forbid_domain_literals" below. This is not
# recommended for today's Internet.
# DO NOT ALLOW HOST LITERALS
# These defaults work for us; you may wish to uncomment the line
# below and change the allow_domain_literals line below to true
# to allow domain literals in your environment
# local_domains_include_host_literals
# The following line prevents Exim from recognizing addresses of the form
# "user@[111.111.111.111]" that is, with a "domain literal" (an IP address)
# instead of a named domain. The RFCs still require this form, but it makes
# little sense to permit mail to be sent to specific hosts by their IP address
# in the modern Internet, and this ancient format has been used by those
# seeking to abuse hosts by using them for unwanted relaying. If you really
# do want to support domain literals, remove the following line, and see
# also the "domain_literal" router below.
allow_domain_literals = false
# No local deliveries will ever be run under the uids of these users (a colon-
# separated list). An attempt to do so gets changed so that it runs under the
# uid of "nobody" instead. This is a paranoic safety catch. Note the default
# setting means you cannot deliver mail addressed to root as if it were a
# normal user. This isn't usually a problem, as most sites have an alias for
# root that redirects such mail to a human administrator.
never_users = root
# DO HOST LOOKUP
# The setting below causes Exim to do a reverse DNS lookup on all incoming
# IP calls, in order to get the true host name. If you feel this is too
# expensive, you can specify the networks for which a lookup is done, or
# remove the setting entirely.
host_lookup = *
# DISALLOW IDENT CALLBACKS
# Exim may be set to make RFC 1413 (ident) callbacks for all incoming SMTP
# calls. You can limit the hosts to which these calls are made, and/or change
# the timeout that is used. If you set the timeout to zero, all RFC 1413 calls
# are disabled. RFC 1413 calls are cheap and can provide useful information
# for tracing problem messages, but some hosts and firewalls have problems
# with them. This can result in a timeout instead of an immediate refused
# connection, leading to delays on starting up an SMTP session. By default
# we disable callbacks for incoming SMTP calls. You may change
# rfc1413_query_timeout to 30s or some other positive number of seconds to
# enable callbacks for incoming SMTP calls.
rfc1413_hosts = *
rfc1413_query_timeout = 0s
# BOUNCE MESSAGES
# When Exim can neither deliver a message nor return it to sender, it
# "freezes" the delivery error message (aka "bounce message"). There are also
# other circumstances in which messages get frozen. They will stay on the
# queue forever unless one or both of the following options is set.
# This option unfreezes bounce messages after two days, tries
# once more to deliver them, and ignores any delivery failures.
ignore_bounce_errors_after = 2d
# This option cancels (removes) frozen messages that are older than five days.
timeout_frozen_after = 5d
# TRUSTED USERS
# if you must add additional trusted users, do so here; continue the
# colon-delimited list
trusted_users = mail:majordomo:apache:diradmin
# SSL/TLS cert and key
tls_certificate = /etc/exim.cert
tls_privatekey = /etc/exim.key
tls_advertise_hosts = *
#auth_over_tls_hosts = *
# ACLs #
begin acl
# ACL that is used after the RCPT command
check_recipient:
# to block certain wellknown exploits, Deny for local domains if
# local parts begin with a dot or contain @ % ! / |
deny domains = +local_domains
local_parts = ^[.] : ^.*[@%!/|]
# to restrict port 587 to authenticated users only
# see also daemon_smtp_ports above
accept hosts = +auth_relay_hosts
condition = ${if eq {$interface_port}{587} {yes}{no}}
endpass
message = relay not permitted, authentication required
authenticated = *
# allow local users to send outgoing messages using slashes
# and vertical bars in their local parts.
# Block outgoing local parts that begin with a dot, slash, or vertical
# bar but allows them within the local part.
# The sequence \..\ is barred. The usage of @ % and ! is barred as
# before. The motivation is to prevent your users (or their virii)
# from mounting certain kinds of attacks on remote sites.
deny domains = !+local_domains
local_parts = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
# local source whitelist
# accept if the source is local SMTP (i.e. not over TCP/IP).
# Test for this by testing for an empty sending host field.
accept hosts = :
# sender domains whitelist
# accept if sender domain is in whitelist
accept sender_domains = +whitelist_domains
# sender hosts whitelist
# accept if sender host is in whitelist
accept hosts = +whitelist_hosts
accept hosts = +whitelist_hosts_ip
# envelope senders whitelist
# accept if envelope sender is in whitelist
accept senders = +whitelist_senders
# accept mail to postmaster in any local domain, regardless of source
accept local_parts = postmaster
# accept mail to abuse in any local domain, regardless of source
accept local_parts = abuse
# accept mail to hostmaster in any local domain, regardless of source
accept local_parts = hostmaster
domains =+local_domains
# If the page you're using to notify senders of blocked email of how
# to get their address unblocked will use a web form to send you email so
# you'll know to unblock those senders, then you may leave these lines
# commented out. However, if you'll be telling your senders of blocked
# email to send an email to [email protected], then you should
# replace "errors" with the left side of the email address you'll be
# using, and "example.com" with the right side of the email address and
# then uncomment the second two lines, leaving the first one commented.
# Doing this will mean anyone can send email to this specific address,
# even if they're at a blocked domain, and even if your domain is using
# blocklists.
# accept mail to [email protected], regardless of source
# accept local_parts = errors
# domains = example.com
# deny so-called "legal" spammers"
deny message = Email blocked by LBL - to unblock see http://www.example.com/
# only for domains that do want to be tested against RBLs
domains = +use_rbl_domains
sender_domains = +blacklist_domains
# deny using hostname in bad_sender_hosts blacklist
deny message = Email blocked by BSHL - to unblock see http://www.example.com/
hosts = +bad_sender_hosts
# deny using IP in bad_sender_hosts blacklist
hosts = +bad_sender_hosts_ip
# deny using email address in blacklist_senders
deny message = Email blocked by BSAL - to unblock see http://www.example.com/
domains = use_rbl_domains
deny senders = +blacklist_senders
# By default we do NOT require sender verification.
# Sender verification denies unless sender address can be verified:
# If you want to require sender verification, i.e., that the sending
# address is routable and mail can be delivered to it, then
# uncomment the next line. If you do not want to require sender
# verification, leave the line commented out
#require verify = sender
# deny using spamhaus
deny message = Email blocked by SPAMHAUS - to unblock see http://www.example.com/
hosts = !+relay_hosts
!authenticated = *
dnslists = zen.spamhaus.org
# deny using njabl
deny message = Email blocked by NJABL - to unblock see http://www.example.com/
!authenticated = *
dnslists = dnsbl.njabl.org
# deny using cbl
deny message = Email blocked by CBL - to unblock see http://www.example.com/
!authenticated = *
dnslists = cbl.abuseat.org
# deny using list.dsbl.org (single stage open SMTP relays)
deny message = Email blocked by DSBL - to unblock see http://www.example.com/
domains =+use_rbl_domains
!authenticated = *
dnslists = list.dsbl.org
# deny using bl.spamcannibal.org : see http://www.spamcannibal.org/cannibal.cgi
# moved to last place to check logs to see how much it blocks
# note if using spamcannibal you should probably whitelist constantcontact.com
deny message = Email blocked by SPAMCANNIBAL - to unblock see http://www.example.com/
!authenticated = *
dnslists = bl.spamcannibal.org
# deny using sorbs name based list
deny message = Email blocked by SORBS - to unblock see http://www.example.com/
# rhsbl list is name based
dnslists = rhsbl.sorbs.net/$sender_address_domain
# accept if address is in a local domain as long as recipient can be verified
accept domains = +local_domains
endpass
message = "Unknown User"
verify = recipient
# accept if address is in a domain for which we relay as long as recipient
# can be verified
accept domains = +relay_domains
endpass
verify=recipient
# accept if message comes for a host for which we are an outgoing relay
# recipient verification is omitted because many MUA clients don't cope
# well with SMTP error responses. If you are actually relaying from MTAs
# then you should probably add recipient verify here
accept hosts = +relay_hosts
endpass
message = authentication required
authenticated = *
deny message = relay not permitted
# default at end of acl causes a "deny", but line below will give
# an explicit error message:
# ACL that is used after the DATA command
check_message:
accept
# AUTHENTICATION CONFIGURATION #
# There are no authenticator specifications in this default configuration file.
begin authenticators
plain:
driver = plaintext
public_name = PLAIN
server_prompts = :
server_condition = "${perl{smtpauth}}"
server_set_id = $2
login:
driver = plaintext
public_name = LOGIN
server_prompts = "Username:: : Password::"
server_set_id = $1
# REWRITE CONFIGURATION #
# There are no rewriting specifications in this default configuration file.
# ROUTERS CONFIGURATION #
# Specifies how remote addresses are handled #
# ORDER DOES MATTER #
# A remote address is passed to each in turn until it is accepted. #
begin routers
# Remote addresses are those with a domain that does not match any item
# in the "local_domains" setting above.
# This router routes to remote hosts over SMTP using a DNS lookup. Any domain
# that resolves to an IP address on the loopback interface (127.0.0.0/8) is
# treated as if it had no DNS entry.
lookuphost:
driver = dnslookup
domains = ! +local_domains
ignore_target_hosts = 127.0.0.0/8
condition = "${perl{check_limits}}"
transport = remote_smtp
no_more
# This router routes to remote hosts over SMTP by explicit IP address,
# when an email address is given in "domain literal" form, for example,
# <user@[192.168.35.64]>. The RFCs require this facility. However, it is
# little-known these days, and has been exploited by evil people seeking
# to abuse SMTP relays. Consequently it is commented out in the default
# configuration. If you uncomment this router, you also need to comment out
# "forbid_domain_literals" above, so that Exim can recognize the syntax of
# domain literal addresses.
# domain_literal:
# driver = ipliteral
# transport = remote_smtp
# DIRECTORS CONFIGURATION #
# Specifies how local addresses are handled #
# A local address is passed to each in turn until it is accepted. #
# Local addresses are those with a domain that matches some item in the
# "local_domains" setting above, or those which are passed back from the
# routers because of a "self=local" setting (not used in this configuration).
# Spam Assassin
spamcheck_director:
driver = accept
condition = "${if and { \
{!def:h_X-Spam-Flag:} \
{!eq {$received_protocol}{spam-scanned}} \
{!eq {$received_protocol}{local}} \
{exists{/home/${lookup{$domain}lsearch{/etc/virtual/domainowners}{$value}}/.spamassassin/user_prefs}} \
{<{$message_size}{100k}} \
} {1}{0}}"
retry_use_local_part
transport = spamcheck
no_verify
majordomo_aliases:
driver = redirect
allow_defer
allow_fail
data = ${if exists{/etc/virtual/${domain}/majordomo/list.aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/majordomo/list.aliases}}}}
domains = lsearch;/etc/virtual/domainowners
file_transport = address_file
group = daemon
pipe_transport = majordomo_pipe
no_rewrite
user = majordomo
majordomo_private:
driver = redirect
allow_defer
allow_fail
#condition = "${if eq {$received_protocol} {local} {true} {false} }"
condition = "${if or { {eq {$received_protocol} {local}} \
{eq {$received_protocol} {spam-scanned}} } {true} {false} }"
data = ${if exists{/etc/virtual/${domain}/majordomo/private.aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/majordomo/private.aliases}}}}
group = daemon
user = majordomo
domain_filter:
driver = redirect
allow_filter
no_check_local_user
condition = "${if exists{/etc/virtual/${domain}/filter}{yes}{no}}"
user = "mail"
file = /etc/virtual/${domain}/filter
directory_transport = address_file
pipe_transport = virtual_address_pipe
no_verify
uservacation:
driver = accept
condition = ${lookup{$local_part} lsearch {/etc/virtual/${domain}/vacation.conf}{yes}{no}}
require_files = /etc/virtual/${domain}/reply/${local_part}.msg
transport = uservacation
unseen
userautoreply:
driver = accept
condition = ${lookup{$local_part} lsearch {/etc/virtual/${domain}/autoresponder.conf}{yes}{no}}
transport = userautoreply
unseen
virtual_aliases_nostar:
driver = redirect
allow_defer
allow_fail
data = ${if exists{/etc/virtual/${domain}/aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}}}}
group = mail
unseen
#include_domain = true
virtual_user:
driver = accept
#condition = ${if eq {}{${if exists{/etc/virtual/${domain}/passwd}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/passwd}}}}}{no}{yes}}
condition = ${perl{save_virtual_user}}
group = mail
transport = virtual_localdelivery
virtual_aliases:
driver = redirect
allow_defer
allow_fail
condition = ${if eq {}{${if exists{/etc/virtual/${domain}/aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}}}}}{yes}{no}}
data = ${if exists{/etc/virtual/$domain/aliases}{${lookup{$local_part}lsearch*{/etc/virtual/$domain/aliases}}}}
group = mail
#if we have an alias, but no passwd entry we have to drop the email because the
#first alias is unseen (so that you can forward as well as save it)
#The save part is "seen" (virtual_user), but the forward before it isn't. This
#will be the spot where we "see" the email so that it doesn't send a bounce if
#we have an alias but no pop.
drop_solo_alias:
driver = redirect
allow_defer
allow_fail
data = ${if exists{/etc/virtual/$domain/aliases}{${lookup{$local_part}lsearch{/etc/virtual/$domain/aliases}}}}
file_transport = devnull
group = mail
#pipe_transport = virtual_address_pipe
pipe_transport = devnull
# This director handles forwarding using traditional .forward files.
# If you want it also to allow mail filtering when a forward file
# starts with the string "# Exim filter", uncomment the "filter" option.
# The check_ancestor option means that if the forward file generates an
# address that is an ancestor of the current one, the current one gets
# passed on instead. This covers the case where A is aliased to B and B
# has a .forward file pointing to A. The three transports specified at the
# end are those that are used when forwarding generates a direct delivery
# to a file, or to a pipe, or sets up an auto-reply, respectively.
userforward:
driver = redirect
allow_filter
check_ancestor
check_local_user
no_expn
file = $home/.forward
pipe_transport = address_pipe
reply_transport = address_reply
no_verify
system_aliases:
driver = redirect
allow_defer
allow_fail
data = ${lookup{$local_part}lsearch{/etc/aliases}}
# user = exim
localuser:
driver = accept
check_local_user
condition = "${if eq {$domain} {$primary_hostname} {yes} {no}}"
transport = local_delivery
# This director matches local user mailboxes.
# TRANSPORTS CONFIGURATION #
# ORDER DOES NOT MATTER #
# Only one appropriate transport is called for each delivery. #
# A transport is used only when referenced from a director or a router that
# successfully handles an address.
# Spam Assassin
begin transports
spamcheck:
driver = pipe
batch_max = 100
command = /usr/sbin/exim -oMr spam-scanned -bS
current_directory = "/tmp"
group = mail
home_directory = "/tmp"
log_output
message_prefix =
message_suffix =
return_fail_output
no_return_path_add
transport_filter = /usr/bin/spamc -u ${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}
use_bsmtp
user = mail
# must use a privileged user to set $received_protocol on the way back in!
#majordomo
majordomo_pipe:
driver = pipe
group = daemon
return_fail_output
user = majordomo
# This transport is used for local delivery to user mailboxes in traditional
# BSD mailbox format. By default it will be run under the uid and gid of the
# local user, and requires the sticky bit to be set on the /var/mail directory.
# Some systems use the alternative approach of running mail deliveries under a
# particular group instead of using the sticky bit. The commented options below
# show how this can be done.
local_delivery:
driver = appendfile
delivery_date_add
envelope_to_add
directory = /home/$local_part/Maildir/
directory_mode = 770
create_directory = true
maildir_format
group = mail
mode = 0660
return_path_add
user = ${local_part}
## for delivering virtual domains to their own mail spool
virtual_localdelivery:
driver = appendfile
create_directory
delivery_date_add
envelope_to_add
directory = /home/${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}/imap/${domain}/${local_part}/Maildir
maildir_format
group = mail
mode = 660
return_path_add
user = "${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}"
quota = ${if exists{/etc/virtual/${domain}/quota}{${lookup{$local_part}lsearch*{/etc/virtual/${domain}/quota}{$value}{0}}}{0}}
## vacation transport
uservacation:
driver = autoreply
file = /etc/virtual/${domain}/reply/${local_part}.msg
from = "${local_part}@${domain}"
log = /etc/virtual/${domain}/reply/${local_part}.log
no_return_message
subject = "${if def:h_Subject: {Autoreply: ${quote:${escape:$h_Subject:}}} {I am on vacation}}"
text = "\
------ ------\n\n\
This message was automatically generated by email software\n\
The delivery of your message has not been affected.\n\n\
------ ------\n\n"
to = "${sender_address}"
user = mail
#once = /etc/virtual/${domain}/reply/${local_part}.once
userautoreply:
driver = autoreply
bcc = ${lookup{${local_part}} lsearch {/etc/virtual/${domain}/autoresponder.conf}{$value}}
no_return_message
subject = "${if def:h_Subject: {Autoreply: ${quote:${escape:$h_Subject:}}} {Autoreply Message}}"
user = mail
devnull:
driver = appendfile
file = /dev/null
# This transport is used for delivering messages over SMTP connections.
remote_smtp:
driver = smtp
# This transport is used for handling pipe deliveries generated by alias
# or .forward files. If the pipe generates any standard output, it is returned
# to the sender of the message as a delivery error. Set return_fail_output
# instead of return_output if you want this to happen only when the pipe fails
# to complete normally. You can set different transports for aliases and
# forwards if you want to - see the references to address_pipe in the directors
# section below.
address_pipe:
driver = pipe
return_output
virtual_address_pipe:
driver = pipe
group = nobody
return_output
user = "${lookup{$domain}lsearch* {/etc/virtual/domainowners}{$value}}"
# This transport is used for handling deliveries directly to files that are
# generated by aliasing or forwarding.
address_file:
driver = appendfile
delivery_date_add
envelope_to_add
return_path_add
# This transport is used for handling autoreplies generated by the filtering
# option of the forwardfile director.
address_reply:
driver = autoreply
# RETRY CONFIGURATION #
# This single retry rule applies to all domains and all errors. It specifies
# retries every 15 minutes for 2 hours, then increasing retry intervals,
# starting at 1 hour and increasing each time by a factor of 1.5, up to 16
# hours, then retries every 8 hours until 4 days have passed since the first
# failed delivery.
# Domain Error Retries
begin retry
* * F,2h,15m; G,16h,1h,1.5; F,4d,8h
# End of Exim 4 configuration
Are you trying to block incoming spam? If so, blocklists will block much of it.
If you're trying to block outgoing spam, then find and fix the holes in your system.
Perhaps I wasn't clear. Are you trying to block incoming spam or outgoing spam?
2007-12-30 18:40:51 1J8uk9-00081u-6N == [email protected] R=lookuphost T=remote_smtp defer (-18): Remote host eppsaviation.com.s6b2.psmtp.com [64.18.5.14] closed connection in response to initial connection
2007-12-30 18:40:57 1J8uLd-0007T4-63 => [email protected] F=<[email protected]> R=lookuphost T=remote_smtp S=1993 H=uecsh.com [202.136.212.35] C="250 ok"
2007-12-30 18:40:57 1J8uLd-0007T4-63 -> [email protected] F=<[email protected]> R=lookuphost T=remote_smtp S=1993 H=uecsh.com [202.136.212.35] C="250 ok"
2007-12-30 18:40:57 1J8uLd-0007T4-63 => [email protected] F=<[email protected]> R=lookuphost T=remote_smtp S=1993 H=mail.uecsh.com [202.136.212.35] C="250 ok"
2007-12-30 18:40:57 1J8uLd-0007T4-63 -> [email protected] F=<[email protected]> R=lookuphost T=remote_smtp S=1993 H=mail.uecsh.com [202.136.212.35] C="250 ok"
2007-12-30 18:40:57 1J8uLd-0007T4-63 Completed
2007-12-30 18:41:14 1J8ugN-0007uY-9O SMTP timeout while connected to mx0.dixie-net.com [64.89.160.52] after initial connection: Connection timed out
2007-12-30 18:41:29 1J8ugy-0007ud-Cv SMTP timeout while connected to smail.downman.com [211.115.215.149] after initial connection: Connection timed out
2007-12-30 18:41:29 1J8ugy-0007ud-Cv == [email protected] R=lookuphost T=remote_smtp defer (110): Connection timed out: SMTP timeout while connected to smail.downman.com [211.115.215.149] after initial connection
Dauser2007,
Do you realize that exim is an integral part of your system? If you remove exim you won't be able to process any mail on your server. No mail will enter or leave your server. Not even server messages to you. All your domains' email will have to be handled by some other server somewhere else.
There are less drastic ways to eliminate spam, such as enabling SpamBlocker and SpamAssassin, and using SpamFiltering.
