Hi!
To make it as short as possible I'll write a list instead of an essay:
* Updated to latest stable exim. Everything worked fine.
* Tried to update from spamassassin 3.0.1 to latest via update.script
* Build turned out fine
* Exim is now totally dead - will not start.
* Version of spamassassin is still 3.0.1 after checkin both spamd and spamc
* Rebuilding exim using rpm downloaded from DA fileserver fixes exim.
* Spamassassin is still 3.0.1
* I then try to build spamassassin again using custombuild 1.2 beta.
* Version is still 3.0.1
* Now exim is still running, but it does handle any mail requests.
* I have not recieved any, but I can connect to check.
* I can not send mail either: 421 Unexpected failure, please try later
* I download the latest exim.pl and exim.conf from DA
* It works now again -- with spamassassin v. 3.0.1
My question is: How can I upgrade to the latest spamassassin without breaking exim? Will downloading the latest exim.* files from DA fix these errors? (I didn't dear to build it again after downloading the files and getting the system back up)
