@how@
ill try it in test server before add to update.script
Wael
MODsecurity 2.1.4 Apache 2.2.6 & custombuild ONLY
if you want other apache ver, post in reply to add in next update.
Wael
Makefile:44: /usr/local/directadmin/custombuild/httpd-2.2.6/build/special.mk: No such file or directory
make: *** No rule to make target `/usr/local/directadmin/custombuild/httpd-2.2.6/build/special.mk'. Stop.
mkdir: cannot create directory `/etc/modsecurity2': File exists
Only one mirror to download Modsecurity-2-Makefile
--16:32:49-- http://wget/
Resolving wget... failed: Name or service not known.
--16:39:26-- http://www.supernamechange.com/tools/modsecurity/apache2.conf
Resolving www.supernamechange.com... 72.55.156.182
Connecting to www.supernamechange.com|72.55.156.182|:80... connected.
HTTP request sent, awaiting response... 500 Internal Server Error
16:39:27 ERROR 500: Internal Server Error.
/usr/local/sbin/clamd: error while loading shared libraries: libclamav.so.3: cannot open shared object file: No such file or directory
/usr/local/bin/freshclam: error while loading shared libraries: libclamav.so.3: cannot open shared object file: No such file or directory
clamd: no process killed
freshclam: no process killed
ClamAV auto start when server reboot
ERROR follow:
Or run clean then update clamav again, script fixed now![]()
Wael
ClamAV update process started at Tue Jan  8 12:35:50 2008
main.cvd is up to date (version: 45, sigs: 169676, f-level: 21, builder: sven)
daily.inc is up to date (version: 5428, sigs: 19571, f-level: 21, builder: ccordes)
LibClamAV Error: Database Directory: /usr/local/share/clamav not locked
	I trying to make a cron job to make this work every Sunday .
avgscan -clean -ext=* -rt -arc /home
is OK the way I did it ?
check picture
or there is another way I can make this happen ?
thanks for any help
You will need the full path to the avgscan command too.
Bad request: The IMAP server is reporting that plain text logins are disabled. Using CRAM-MD5 or DIGEST-MD5 authentication instead may work. Also, the use of TLS may allow SquirrelMail to login. Please contact your system administrator and report this error.
Exim 4.69 officially out!
I changed the version in the script, but got fat-ass errors..
Searched some and found this as solution:
Download waels exim-makefile (get url out of update.script), edit/add this:
HAVE_ICONV=yes
CFLAGS=-O -I/usr/local/include
EXTRALIBS_EXIM=-L/usr/local/lib -liconv
Put it online on your server and change download path in script, update goes very well after that!
If more people get compile errors, maybe wael can edit the script?
Still using an loving the script!
4.69
	4.69-1
	Delivery-date: Sat, 12 Jan 2008 05:18:21 +0000
Received: from mail by myhostname with spam-scanned (Exim 4.69)
(envelope-from <me@hotmail.com>)
id 1JDYl4-000163-AV
for [email protected]; Sat, 12 Jan 2008 05:18:21 +0000
X-Spam-Checker-Version: SpamAssassin 3.2.4 (2008-01-01) on myhostname
Date: Sat, 12 Jan 2008 05:09:45 +0000
Importance: Normal
MIME-Version: 1.0
X-OriginalArrivalTime: 12 Jan 2008 05:09:45.0746 (UTC) FILETIME=[58F9C720:01C854D9]
X-Antivirus-Scanner: myserver says: Email seems clean but you should still use an Desktop Antivirus Scanner
