Updating SSL Cert won't work
redeye
[SOLVED]
I have a problem with updating my expired ssl certificate.
I've followed these instructions: http://www.site-helper.com/ssl.html
generated a new csr and purchased a new one with godaddy. Installing the cert wil give no errors. Updating the CA Root will give:
Success!
Details
CA Certificate is ok. Your site should be secure within a few minutes.
NP, i think, but what ever I try, my old, expired cert is used.
I've restarted httpd, checked the httpd.conf, it's correct. The .key .cert and .cacert are updated in the ..../data/users/---/ directory.
:S What am I missing?
Help is appreciated. :confused:
Try a manual httpd restart.
If that doesn't work, check the files at the command line to see if they're in the right place; specifically check the domain-specific httpd.conf file.
Jeff,
Did all of this, still no working. I'm missing something, I'm sure, but what ?????
Someone's going to have to look at your system to figure it out. Have you asked GoDaddy support?
No not yet, I think it's not the certificate, but my machine where the problem is. I issued a certificate on IIS without problems. :S
UPDATE: John helped me with the sollution :D. The site was not the default site on that IP. Set it default and GO.
Thanks all for helping.
