Multiserver, remove one server as nameserver
nieuwhier
Netherlands
I have multiple servers that use Multiserver. Works great but I have a question when I remove one from the multiserver screen.
Multiserver Situation now:
1) server A -> Server B and Server C
2) Server B -> Server A and Server C
3) Server C -> Server A and Server B
The rest of the servers all sync to Server A and B, no problem there.
I want to remove Server C as a multiserver from lines 1 and 2. That is not to difficult but when I delete server C all the DNS information from server A and B are still on server C. How do I get rid of that ?
Regards,
Michel.
There is no unsync at this time.. so the answer would probably be manually.
If you delete the zones while still synced, then they'll be removed from the remote box as well, but I'm guessing you don't want them deletd from the original, just remove from the external dns boxes.... so in that case, manual remove *after* removing the multiserver IPs from the list.. (or else you will end up deleting it from the primary if they're still hooked up together)
