How to use SpamAssassin bayesian filters?
BlueNoteWeb
Denton, TX
I'm probably just completely overlooking something - hopefully someone can help me out on this.
I've installed SpamAssassin on my server following the instructions here:
http://help.directadmin.com/item.php?id=36
It's working pretty well. Incoming emails are scanned, some are marked as spam and they're moved to the user's spam folder as per the settings.
The next step is the bayesian filter - how do I teach SA what's spam and what's not? If I move a message from my inbox to my spam folder, will that do it, or is there another step to take?
You either need to manually train it using sa-learn from the command line, or you can configure it to train based on the contents of an IMAP folder as part of a cron job (harder). If the spam has been forwarded to you then this gets much harder!
I don't have the time at the moment to go through this in detail but would suggest you start by reading the entire spamassassin wiki (preferably twice) and then have a good browse through the spamassassin forum / mailing list.
http://wiki.apache.org/spamassassin/
http://www.nabble.com/SpamAssassin-f191.html
This should run sa-learn on all the spam in your users folders
 for i in `find /home/ -type d -name .INBOX.spam`; do sa-learn --spam $i/cur; sa-learn --spam $i/new;done
this is slightly better
 for i in `find /home/ -type d -name .INBOX.spam`; do sa-learn --spam $i/{cur,new};done
... prolly should use xargs instead of a for loop
ah xargs
find /home/ -type d -wholename */.INBOX.spam/cur -o -wholename */.INBOX.spam/new | xargs sa-learn --spam
or
find /home/ -type d \( -wholename */.INBOX.spam/cur -o -wholename */.INBOX.spam/new \) | xargs sa-learn --spam
