walo
- Mar 19, 2005
This is the first release of the PHP Version selector plugin.
PHP Version selector allow users to select which version of php want to use on each domain.
Of course, the server must have 2 different version of PHP installed.
It support PHP4, PHP5 and PHP6, on CLI o CGI mode. You can do any combination.
Download: http://www.outservices.net/da/phpvs.php
Screenshots:
Admin config: http://www.outservices.net/da/phpvs_sadmin.png
User panel: http://www.outservices.net/da/phpvs_suser.png
FAQs:
How does it work?
The simple way you use a different version of PHP on a website, is to create a .htaccess file and set the mime type of the php version. Well, PHP Version selector does this.
What happen if an existing .htaccess file is on the public_html folder of the domain?
Don't worry, PHP Version Selector add a new line without altering the actual content.
Default mime type does not work on my server
You can change it. It is very easy.
My entry panel is in other language and my users don't understand english
PHP Version selector allow you to change the language. Just edit the 4 lines on /usr/local/directadmin/plugins/phpvs/data/lang.txt
It is safe to use it?
Totally. This plugin only create and/or edit an .htaccess file. If something goes bad, you can revert all.
When i change the PHP version of a site i get error 500 Internal server error
In this case check the PHP Version selector configuration and make sure that match with you PHP version installed. Also you can check the mime types and the .htaccess file of the domain.
Where is the .htaccess file created?
For now, PHP Version selector only support domain, the .htaccess file is created on the public_html folder of each domain.
It is free?
No fees, no encrypted files. It is 100% free.
Screenshots:
FAQs:
How does it work?
It is free?
