Help with "Connection attempt to UDP" logs and my firewall.
labrocca
This is a very consistent message in my logs (/var/log/messages). How do I firewall this out? I use ipfw and freebsd.
Feb 20 20:24:50 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:54120
Feb 20 20:24:50 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:49660
Feb 20 20:24:50 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:49661
Feb 20 20:24:50 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:54594
Feb 20 20:25:02 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:59400
Feb 20 20:25:02 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:58385
Feb 20 20:25:13 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:65044
Feb 20 20:25:14 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:64506
Feb 20 20:25:19 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:60665
Feb 20 20:25:19 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:54429
Feb 20 20:25:19 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:52896
Feb 20 20:25:19 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:55425
Feb 20 20:25:19 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:61704
Feb 20 20:25:19 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:61705
Feb 20 20:25:19 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:61706
Feb 20 20:25:19 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:61707
Feb 20 20:25:25 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:51328
Feb 20 20:25:26 ns1 kernel: Connection attempt to UDP [::0001]:53 from [::0001]:65493
Here are my firewall rules:
# ipfw Firewall Commands
cmd="ipfw -q add"
ipfw -q -f flush
# Allow Loopback and Deny Loopback Spoofing
$cmd allow all from any to any via lo0
$cmd deny all from any to 127.0.0.0/8
$cmd deny all from 127.0.0.0/8 to any
$cmd deny tcp from any to any frag
#bad guys
$cmd deny ip from 217.160.240.78 to me
# Stateful rules
$cmd check-state
$cmd deny tcp from any to any established
$cmd allow all from any to any out keep-state
$cmd allow icmp from any to any
# Incoming/Outgoing Services
$cmd allow tcp from any to any 21 setup keep-state
$cmd allow tcp from any to any 22 setup keep-state
$cmd allow tcp from any to any 25 setup keep-state
$cmd allow tcp from any to any 53 setup keep-state
$cmd allow udp from any to any 53 keep-state
$cmd allow tcp from any to any 80 setup keep-state
$cmd allow tcp from any to any 110 setup keep-state
$cmd allow tcp from any to any 143 setup keep-state
$cmd allow tcp from any to any 443 setup keep-state
$cmd allow tcp from any to any 2222 setup keep-state
$cmd allow tcp from any to any 32555-32565 in setup keep-state
# Deny and Log
$cmd deny log all from any to any
Any help is appreciated.
EDIT: found out this is being caused by sysctl and the net.inet.udp.log_in_vain parameter being turned on. I have turned it off for now but would rather have it on and these packets dropped completely or firewalled. I count about 2 per second on my server.
To add to chatwizrd's reply: it's an IPv6 connection from localhost to your BIND port.
It's most likely harmless. You can disable IPv6 if you don't need it.
Thanks for help sirs. I rebuilt the kernel without any IPv6 support and shut it off in rc.conf as well...seems to have fixed the problem.
Thanks.
EDIT:
Doh...now I get this:
Feb 25 14:15:43 ns1 kernel: Connection attempt to UDP 127.0.0.1:61266 from 127.0.0.1:53
Feb 25 14:15:43 ns1 kernel: Connection attempt to UDP 66.36.237.161:53406 from 66.36.237.161:53
Feb 25 14:17:49 ns1 kernel: Connection attempt to UDP 127.0.0.1:56639 from 127.0.0.1:53
Feb 25 14:18:15 ns1 kernel: Connection attempt to UDP 127.0.0.1:56639 from 127.0.0.1:53
Feb 25 14:22:43 ns1 kernel: Connection attempt to UDP 127.0.0.1:43000 from 127.0.0.1:53
Feb 25 14:24:36 ns1 kernel: Connection attempt to UDP 127.0.0.1:3108 from 127.0.0.1:53
So...are these DNS spoof attempts or is there a configuration problem?
It appears your local /etc/resolv.conf has localhost in it.
It's contacting localhost:53 (the way a system does a DNS lookup is via UDP/53).
The high port numbers it comes from, is just the random port (> 1024) that is being used.
You are not beeing spoofed, your system is just attempting to lookup DNS domains.
You need to allow localhost in your firewall rules.
Doesn't that rule allow localhost? Thanks for your help.
I imagine you're having it overwritten by the latter commands:
Order may be the key here.
