FFmpeg-php
protocoles
Hiya Helpers,
today i was trying to install ffmpeg and ffmpeg-php extension.
Ffmpeg was installed without issue but when I'm installing ffmpeg-php it is showing some errors.
FFMPEG:
FFmpeg version SVN-r12406, Copyright (c) 2000-2008 Fabrice Bellard, et al.
configuration: --enable-shared
libavutil version: 49.6.0
libavcodec version: 51.51.0
libavformat version: 52.9.0
libavdevice version: 52.0.0
built on Mar 9 2008 22:17:17, gcc: 3.2.3 20030502 (Red Hat Linux 3.2.3-59)
ffmpeg-php:
# ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for egrep... grep -E
checking for a sed that does not truncate output... /bin/sed
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking whether gcc and cc understand -c and -o together... yes
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for PHP prefix... /usr/local
checking for PHP includes... -I/usr/local/include/php -I/usr/local/include/php/main -I/usr/local/include/php/TSRM -I/usr/local/include/php/Zend
checking for PHP extension directory... /usr/local/lib/php/extensions/no-debug-non-zts-20020429
checking for re2c... exit 0;
checking for gawk... gawk
checking for ffmpeg support... yes, shared
checking for ffmpeg headers... configure: error: ffmpeg headers not found. Make sure you've built ffmpeg as shared libs using the --enable-shared option
don't know why it's showing that error
thanks for help
cp /usr/local/include/libavcodec/* /usr/local/include/ffmpeg
cp /usr/local/include/libavdevice/* /usr/local/include/ffmpeg
cp /usr/local/include/libavformat/* /usr/local/include/ffmpeg
cp /usr/local/include/libavutil/* /usr/local/include/ffmpeg
Hope this helps :)
