problems counting the used disk space
bruno
Argentina - Buenos Aires
I discovered an error when the system go to count user used disk space.
the 'Total Disk Usage (MB)' is not the same when you count all disk usage by domains.
view the image for more details
(Sorry for my english)
----- Español
Descubri un error cuando se actualiza el espacio usado de los usuarios. no coincide con lo usado.
El total representado en 'Total Disk Usage (MB)' no es igual a la suma del espacio usado por cada uno de los dominios.
Dejo una imagen para que vean la difrerencia.
Bruno
That would be because webalizer doesn't take into account sql databases and other files that are owned by the user but not directly associated with the website, such as backups.
Never rely on webalizer for disk usage.
when i do a 'du -sh <user directory/domains/domain.com/public_html>' the total is more than 101MB, it's 400MB
we have the same problem, accessing by root we found the imap folder with emails that from the panel can´t see it
