Apr 25 19:12:15 alpha named[18699]: shutting down
Apr 25 19:12:15 alpha named[18699]: stopping command channel on 127.0.0.1#953
Apr 25 19:12:15 alpha named[18699]: no longer listening on 127.0.0.1#53
Apr 25 19:12:15 alpha named[18699]: no longer listening on 64.125.185.57#53
Apr 25 19:12:15 alpha named[18699]: no longer listening on 208.185.81.9#53
Apr 25 19:12:15 alpha named[18699]: no longer listening on 64.125.185.58#53
Apr 25 19:12:15 alpha named[18699]: no longer listening on 64.125.185.59#53
Apr 25 19:12:15 alpha named[18699]: no longer listening on 64.125.185.60#53
Apr 25 19:12:15 alpha named[18699]: no longer listening on 64.125.185.61#53
Apr 25 19:12:15 alpha named[18699]: exiting
Apr 25 19:12:15 alpha named[18809]: starting BIND 9.3.3rc2 -u named
Apr 25 19:12:15 alpha named[18809]: found 1 CPU, using 1 worker thread
Apr 25 19:12:15 alpha named[18809]: loading configuration from '/etc/named.conf'
Apr 25 19:12:15 alpha named[18809]: listening on IPv4 interface lo, 127.0.0.1#53
Apr 25 19:12:15 alpha named[18809]: listening on IPv4 interface eth0, 64.125.185.57#53
Apr 25 19:12:15 alpha named[18809]: listening on IPv4 interface eth0:10, 208.185.81.9#53
Apr 25 19:12:15 alpha named[18809]: listening on IPv4 interface eth0:0, 64.125.185.58#53
Apr 25 19:12:15 alpha named[18809]: listening on IPv4 interface eth0:1, 64.125.185.59#53
Apr 25 19:12:15 alpha named[18809]: listening on IPv4 interface eth0:2, 64.125.185.60#53
Apr 25 19:12:15 alpha named[18809]: listening on IPv4 interface eth0:3, 64.125.185.61#53
Apr 25 19:12:15 alpha named[18809]: command channel listening on 127.0.0.1#953
Apr 25 19:12:15 alpha named[18809]: zone 0.0.127.in-addr.arpa/IN: loading master file named.local: file not found
Apr 25 19:12:15 alpha named[18809]: zone albarraak.com/IN: loaded serial 2008042101
Apr 25 19:12:15 alpha named[18809]: zone aliaknoiak.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/alraeeseco.com.db:36: mail.alraeeseco.com: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone alraeeseco.com/IN: loading master file /var/named/alraeeseco.com.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone alrouyah.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone ananyah.com/IN: loaded serial 2008042101
Apr 25 19:12:15 alpha named[18809]: zone arinshant.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone bader-art.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone bedirian.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone bokandar.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone buaijan.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone bubyancorp.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone bukandar.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone cggts.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone chicintuition.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/concept5point3.com.db:35: mail.concept5point3.com: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone concept5point3.com/IN: loading master file /var/named/concept5point3.com.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone design-idg.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone einstein9.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone er-ad.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone esh6a.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone eve-tygris.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/expgas.com.db:38: mail.expgas.com: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone expgas.com/IN: loading master file /var/named/expgas.com.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone fawaresholding.com/IN: loaded serial 2008042101
Apr 25 19:12:15 alpha named[18809]: zone kandary.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone kanderi.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone kandery.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone lewisnlambertofs.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone mahyawa.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/mmotribe.com.db:40: mail.mmotribe.com: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone mmotribe.com/IN: loading master file /var/named/mmotribe.com.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone noaimi.com/IN: loaded serial 2008042101
Apr 25 19:12:15 alpha named[18809]: zone noura-moda.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone q8cartoons.com/IN: loaded serial 2008042202
Apr 25 19:12:15 alpha named[18809]: zone q8lawyers.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/shanfa.com.db:38: mail.shanfa.com: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone shanfa.com/IN: loading master file /var/named/shanfa.com.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone silentrunners.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone sou-varne.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone spgroup-kw.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone tribe9.com/IN: loaded serial 2008042001
Apr 25 19:12:15 alpha named[18809]: zone alpha.tribe9.com/IN: loaded serial 2008041600
Apr 25 19:12:15 alpha named[18809]: zone tristarkw.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone trueblue-translation.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone unixgtc.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/upc-kwt.com.db:35: mail.upc-kwt.com: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone upc-kwt.com/IN: loading master file /var/named/upc-kwt.com.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone usbhak.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/vectorisme.com.db:35: mail.vectorisme.com: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone vectorisme.com/IN: loading master file /var/named/vectorisme.com.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone whitehorse-kwt.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone xploitbox.com/IN: loaded serial 2008042201
Apr 25 19:12:15 alpha named[18809]: zone yourrealcards.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone yuyee22.com/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone zokume.com/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone xploitbox.info/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone localhost/IN: loading master file localhost.zone: file not found
Apr 25 19:12:15 alpha named[18809]: zone agool.net/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone alalsun.net/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone bedirian.net/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone crazydevil.net/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone decorum-inc.net/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone einstein9.net/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone iat-rak.net/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone knights-sg.net/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/liquidmemory.net.db:32: mail.liquidmemory.net: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone liquidmemory.net/IN: loading master file /var/named/liquidmemory.net.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone noaimi.net/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone q8cartoon.net/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone q8cartoons.net/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone smsthem.net/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone tdih.net/IN: loaded serial 2008042102
Apr 25 19:12:15 alpha named[18809]: zone tribalsage.net/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone usbhak.net/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: dns_master_load: /var/named/uutc.net.db:35: mail.uutc.net: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone uutc.net/IN: loading master file /var/named/uutc.net.db: CNAME and other data
Apr 25 19:12:15 alpha named[18809]: zone vpnx.net/IN: loaded serial 2008042201
Apr 25 19:12:15 alpha named[18809]: zone xploitbox.net/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone yourrealcards.net/IN: loaded serial 2008042200
Apr 25 19:12:15 alpha named[18809]: zone agool.org/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone da-wiki.org/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: zone tribalsage.org/IN: loaded serial 2008042101
Apr 25 19:12:15 alpha named[18809]: zone obslimited.us/IN: loaded serial 2008042100
Apr 25 19:12:15 alpha named[18809]: running
Apr 25 19:12:15 alpha named[18809]: zone alpha.tribe9.com/IN: sending notifies (serial 2008041600)
Apr 25 19:12:15 alpha named[18809]: zone trueblue-translation.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone tribe9.com/IN: sending notifies (serial 2008042001)
Apr 25 19:12:15 alpha named[18809]: zone cggts.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone agool.net/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone alalsun.net/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone da-wiki.org/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone aliaknoiak.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone tribalsage.net/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone agool.org/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone tribalsage.org/IN: sending notifies (serial 2008042101)
Apr 25 19:12:15 alpha named[18809]: zone zokume.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone esh6a.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone whitehorse-kwt.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone albarraak.com/IN: sending notifies (serial 2008042101)
Apr 25 19:12:15 alpha named[18809]: zone xploitbox.com/IN: sending notifies (serial 2008042201)
Apr 25 19:12:15 alpha named[18809]: zone chicintuition.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone noaimi.com/IN: sending notifies (serial 2008042101)
Apr 25 19:12:15 alpha named[18809]: zone alrouyah.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone design-idg.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone ananyah.com/IN: sending notifies (serial 2008042101)
Apr 25 19:12:15 alpha named[18809]: zone bubyancorp.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone obslimited.us/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone bedirian.net/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone iat-rak.net/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone smsthem.net/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone sou-varne.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone buaijan.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone lewisnlambertofs.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone tristarkw.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone bokandar.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone xploitbox.net/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone noaimi.net/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone bader-art.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone fawaresholding.com/IN: sending notifies (serial 2008042101)
Apr 25 19:12:15 alpha named[18809]: zone tdih.net/IN: sending notifies (serial 2008042102)
Apr 25 19:12:15 alpha named[18809]: zone crazydevil.net/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone mahyawa.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone er-ad.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone bedirian.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone vpnx.net/IN: sending notifies (serial 2008042201)
Apr 25 19:12:15 alpha named[18809]: zone bukandar.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone decorum-inc.net/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone eve-tygris.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone q8cartoons.com/IN: sending notifies (serial 2008042202)
Apr 25 19:12:15 alpha named[18809]: zone usbhak.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone kandery.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone noura-moda.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone q8cartoon.net/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone xploitbox.info/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone knights-sg.net/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone arinshant.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone yuyee22.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone q8cartoons.net/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: client 64.125.185.59#36834: received notify for zone 'alpha.tribe9.com'
Apr 25 19:12:15 alpha named[18809]: zone kanderi.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone silentrunners.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone spgroup-kw.com/IN: sending notifies (serial 2008042100)
Apr 25 19:12:15 alpha named[18809]: zone einstein9.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone usbhak.net/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone yourrealcards.net/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone q8lawyers.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone yourrealcards.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone einstein9.net/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone kandary.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: zone unixgtc.com/IN: sending notifies (serial 2008042200)
Apr 25 19:12:15 alpha named[18809]: client 64.125.185.59#36834: received notify for zone 'tribe9.com'
Apr 25 19:13:35 alpha named[18809]: lame server resolving 'c9359430.virtua.com.br' (in 'virtua.com.br'?): 201.6.0.102#53
Apr 25 19:16:11 alpha named[18809]: unexpected RCODE (REFUSED) resolving '18.150.46.195.in-addr.arpa/PTR/IN': 213.194.65.36#53
