PHP Problem : session_start() open failed: Permission denied
tdldp
Hi everyone...
After using custombuild, to update to php5 (CLI) / Apache 2
i have webmail that doesn't function anymore...
I have indeed following errors :
[Tue May 06 14:04:00 2008] [error] [client ] PHP Warning:  session_start() [<a href='function.session-start'>function.session-start</a>]: open(/tmp/sess_0j3vtsc0gt0721he2bhok02tg5, O_RDWR) failed: Permission denied (13) in /var/www/html/webmail/inc/inc.php on line 21, referer: http://domain.tdl/webmail/
[Tue May 06 14:04:12 2008] [error] [client ] PHP Warning:  session_start() [<a href='function.session-start'>function.session-start</a>]: open(/tmp/sess_0j3vtsc0gt0721he2bhok02tg5, O_RDWR) failed: Permission denied (13) in /var/www/html/webmail/inc/inc.php on line 21, referer: http://domain.tdl/webmail/index.php?tid=outlook&lid=fr
[Tue May 06 14:04:55 2008] [error] [client ] PHP Warning:  session_start() [<a href='function.session-start'>function.session-start</a>]: open(/tmp/sess_0j3vtsc0gt0721he2bhok02tg5, O_RDWR) failed: Permission denied (13) in /var/www/html/webmail/inc/inc.php on line 21, referer: http://domain.tdl/webmail/index.php?tid=outlook&lid=fr
[Tue May 06 14:05:01 2008] [error] [client ] PHP Warning:  session_start() [<a href='function.session-start'>function.session-start</a>]: open(/tmp/sess_0j3vtsc0gt0721he2bhok02tg5, O_RDWR) failed: Permission denied (13) in /var/www/html/webmail/inc/inc.php on line 21, referer: http://domain.tdl/webmail/index.php?tid=outlook&lid=fr
[Tue May 06 14:05:07 2008] [error] [client ] PHP Warning:  session_start() [<a href='function.session-start'>function.session-start</a>]: open(/tmp/sess_0j3vtsc0gt0721he2bhok02tg5, O_RDWR) failed: Permission denied (13) in /var/www/html/webmail/inc/inc.php on line 21, referer: http://domain.tdl/webmail/index.php?tid=outlook&lid=fr
Ok so problem with /tmp session directory.
Made some checks :
- /tmp : chmod is 777 - owner : 0 - group : 0
- sess_x : are chmod 600 - owner : x - group : x owner / group correspond to webuser account and group.
- webmail is run under owner : webmail group : webmail
How do i cope this case so that tmp session files are readable for all webusers, and also other web applications (webmail, phpmyadmin and other roundcube and squirrelmail).
How do i cope new files readable writable by all necessary users ???
Is there something to check with umask ??? (and if yes what ???)
Thanks for your help
Do you have secured you tmp directory? Try to chmod your tmp folder to: rwxrwxrwt (1777)
chmod /tmp is 1777
inside files are automatically created under user / group chmod 600
i guess it has to do with umask... but how do i change this for this folder so that it runs under chmod 666
Is there risk to give read/write permissions to session files ???
Tdldp
Session file have to be created with 600 and owner the apache user.
webmail programs run through apache user so they can read the tmp session files.
are you sure that the apache2 user is the same user with your apache 1 installation?
what kind of os are you using?
have you tried to delete them and restart apache?
can you paste the result of :
ps auxww |grep httpd
and
ls -la /tmp
i have different users for apache services :
www-data 33 33 /var/www
apache 1000 107 /var/www
How do i check what you demand.
i'm using Debian 4.0
Yes but weirdly it doesn't produce same problems between all accounts...
Certain will work correctly for webmail, others no...
venus:~# ps auxww |grep httpd
apache 2083 0.0 0.9 15724 9892 ? S 20:01 0:00 /usr/sbin/httpd -k start -DSSL
apache 2443 0.0 0.9 15524 9692 ? S 20:03 0:00 /usr/sbin/httpd -k start -DSSL
apache 4321 0.0 0.9 15732 9892 ? S 20:27 0:00 /usr/sbin/httpd -k start -DSSL
apache 4755 0.0 0.9 15740 9796 ? S 20:32 0:00 /usr/sbin/httpd -k start -DSSL
apache 4772 0.0 0.9 15768 9816 ? S 20:32 0:00 /usr/sbin/httpd -k start -DSSL
apache 5328 0.0 0.9 15736 9880 ? S 20:37 0:00 /usr/sbin/httpd -k start -DSSL
apache 5351 0.0 0.9 15896 10048 ? S 20:37 0:00 /usr/sbin/httpd -k start -DSSL
apache 5619 0.0 0.9 15768 9932 ? S 20:40 0:00 /usr/sbin/httpd -k start -DSSL
apache 5887 0.0 0.9 15724 9884 ? S 20:41 0:00 /usr/sbin/httpd -k start -DSSL
apache 6065 0.0 0.9 15508 9640 ? S 20:42 0:00 /usr/sbin/httpd -k start -DSSL
apache 6244 0.0 0.9 15724 9868 ? S 20:43 0:00 /usr/sbin/httpd -k start -DSSL
apache 6554 0.0 0.9 15504 9644 ? S 20:45 0:00 /usr/sbin/httpd -k start -DSSL
apache 6716 0.0 0.9 15768 9804 ? S 20:47 0:00 /usr/sbin/httpd -k start -DSSL
apache 6920 0.0 0.9 15496 9588 ? S 20:49 0:00 /usr/sbin/httpd -k start -DSSL
apache 7008 0.0 0.9 15488 9532 ? S 20:50 0:00 /usr/sbin/httpd -k start -DSSL
root 7142 0.0 0.0 3968 704 pts/0 R+ 20:51 0:00 grep httpd
root 11467 0.0 1.0 15300 10288 ? Ss May08 0:00 /usr/sbin/httpd -k start -DSSL
venus:~#
and
ls -la /tmp
I cannot copy everything as there is approx 13 000 session files that are never purged (only after manual purge i make)
But here is last 150 files :
-rw------- 1 surgerauto surgerauto 29 2008-05-07 02:39 sess_vjjtc2j6d8glkqtmgadflk7jl6
-rw------- 1 loireauto loireauto 0 2008-05-10 18:33 sess_vjniu577sq5vc1ifthjhfc9bp5
-rw------- 1 renlannion renlannion 0 2008-05-08 14:17 sess_vjores7ir5qm980ds9h5gptdr3
-rw------- 1 abmotors abmotors 0 2008-05-12 17:22 sess_vjqcgh5vsjga4tnp0n8s1jacq7
-rw------- 1 rhinrhone rhinrhone 0 2008-05-10 18:56 sess_vjqf2t3uimi8i08ttjghe0cca6
-rw------- 1 aa31 aa31 85 2008-05-11 21:47 sess_vk012kujboh75b6spq33mil8p3
-rw------- 1 fpa fpa 0 2008-05-12 04:21 sess_vk14206a2bblfb25m8na6jg3r0
-rw------- 1 atlantic atlantic 0 2008-05-12 10:45 sess_vk664m1ukp7huneura377afor6
-rw------- 1 renlannion renlannion 0 2008-05-11 19:40 sess_vk8gnloknec1tgua1plf4o18f7
-rw------- 1 chrisauto chrisauto 0 2008-05-11 18:15 sess_vkfsbgafsf9tjms9tscet5n8q3
-rw------- 1 planetauto planetauto 22 2008-05-06 22:22 sess_vki5libbjvms8r4500mt8ptlb2
-rw------- 1 surpluauto surpluauto 0 2008-05-12 12:45 sess_vkmbiov9skte6tnji3rfn106h3
-rw------- 1 hart hart 22 2008-05-11 15:37 sess_vkmu64irefdmkgicqvbr3d9s87
-rw------- 1 vtmauto vtmauto 0 2008-05-12 11:28 sess_vkpc5ka4fo2p0ptb5bdchml8n4
-rw------- 1 planetauto planetauto 0 2008-05-10 05:00 sess_vks465ndu4v23249nralu0nu90
-rw------- 1 dgdif dgdif 561 2008-05-08 19:55 sess_vksisq591u9dqumuev50jg7131
-rw------- 1 loireauto loireauto 0 2008-05-10 18:33 sess_vkvj7lpkcpc7242gtkups4joo4
-rw------- 1 surpluauto surpluauto 57 2008-05-08 02:08 sess_vl22vn1qjcfrrr7fn3gcbivqo2
-rw------- 1 profilcar profilcar 0 2008-05-11 12:44 sess_vl5ktsn67a0is0qva3liigi843
-rw------- 1 accelauto accelauto 0 2008-05-11 11:45 sess_vl5shc3p7s0k0663km29beljm6
-rw------- 1 dafa dafa 0 2008-05-12 18:36 sess_vlak0p3rdosvdehg7p1q1raek2
-rw------- 1 fbauto fbauto 22 2008-05-12 20:44 sess_vle0oad0ri2btk082hqjdh2g15
-rw------- 1 planetauto planetauto 0 2008-05-06 05:27 sess_vleqmjq9v8h59kl57sn8vt1oj5
-rw------- 1 aa31 aa31 0 2008-05-06 10:06 sess_vlfd5ie8dhtj0820ssg75vo4f0
-rw------- 1 bmcauto bmcauto 0 2008-05-10 16:46 sess_vlfgapa155lq0c7bo9v9qfstd0
-rw------- 1 hart hart 0 2008-05-11 06:09 sess_vlj6rmt0fq40g0ah1eh6fn5fp2
-rw------- 1 rhinrhone rhinrhone 22 2008-05-07 14:15 sess_vlk5mprj68l5urkm17ptv4bqd7
-rw------- 1 and and 0 2008-05-12 07:04 sess_vln0mlpqk5mfmte59d8pj2t451
-rw------- 1 planetauto planetauto 22 2008-05-08 01:09 sess_vm08q2j25saggmbisuh1p01m35
-rw------- 1 loireauto loireauto 0 2008-05-12 09:53 sess_vm0igho6l3dhstgkqcai5m3e37
-rw------- 1 autofrance autofrance 22 2008-05-06 10:59 sess_vm3sk8spdfjtdn76p7rgd307p4
-rw------- 1 abmotors abmotors 245 2008-05-11 18:40 sess_vm8mpg5er6qai5hqaf64ugvs97
-rw------- 1 fourchene fourchene 0 2008-05-12 06:27 sess_vmaugmv7ss1gcv020ihcj13lu3
-rw------- 1 fourchene fourchene 22 2008-05-09 09:21 sess_vme015ooepi4ur0t2l1e1m8c42
-rw------- 1 groupe3b groupe3b 21 2008-05-06 16:16 sess_vmhnjt8vvee7p06k69g9e5e3g5
-rw------- 1 mionscar mionscar 262 2008-05-11 18:31 sess_vmjqik9n1kip33poq1jggb2674
-rw------- 1 rivat rivat 0 2008-05-12 01:01 sess_vmkaafbu8ji43n5mj79of6rc63
-rw------- 1 mda mda 22 2008-05-10 16:41 sess_vmkvcodc1n3h6dk4971jec4nq1
-rw------- 1 surpluauto surpluauto 0 2008-05-12 12:47 sess_vmlc6k238leqh75rnjtdtjr535
-rw------- 1 leclerc leclerc 0 2008-05-12 17:26 sess_vmnnf77uhmcenln8h9rqsuo3t3
-rw------- 1 renlannion renlannion 0 2008-05-11 21:08 sess_vmqlvl28tlo97u7ktrg2inanh7
-rw------- 1 aca02 aca02 0 2008-05-09 06:10 sess_vmtsngru70hv2g8k2mg8ma9hh0
-rw------- 1 aa31 aa31 0 2008-05-07 16:41 sess_vmv7l2midebntrjfg9s15bngl0
-rw------- 1 surpluauto surpluauto 22 2008-05-10 18:01 sess_vmvc09ns76fdac631eilv414b2
-rw------- 1 renlannion renlannion 0 2008-05-10 05:13 sess_vmvrnph4a405qqi98j1ldnf0l5
-rw------- 1 accelauto accelauto 0 2008-05-06 22:33 sess_vn112d01bmtm35br6d828hv3e1
-rw------- 1 pan44 pan44 0 2008-05-08 05:21 sess_vn2qgcdtpi3od7n2i7vhavd5u4
-rw------- 1 leclerc leclerc 0 2008-05-07 00:57 sess_vn7thcqignldijvt6uepotq4l0
-rw------- 1 fpa fpa 587 2008-05-09 11:43 sess_vn83lp4letrepbptket4pt0i12
-rw------- 1 groupe3b groupe3b 0 2008-05-07 05:03 sess_vnakmfekli8hu4aslbqftq8n95
-rw------- 1 autbonplan autbonplan 0 2008-05-12 01:10 sess_vnd44fo7uhfnd2ph86rni29952
-rw------- 1 pmrauto pmrauto 0 2008-05-09 07:10 sess_vnfupd2bppb3ip7ceavcd0gtq1
-rw------- 1 accelauto accelauto 0 2008-05-08 22:57 sess_vnmpc3r5srkr6b92jui1kh2724
-rw------- 1 rhinrhone rhinrhone 0 2008-05-10 18:55 sess_vnogbb5psu7in1oo9kllkj1t03
-rw------- 1 planetauto planetauto 0 2008-05-06 17:45 sess_vnuv8mr73cvegmdt9n3mm3fjc5
-rw------- 1 abmotors abmotors 0 2008-05-11 19:31 sess_vo1tk9c2ioueq59muibsov4p24
-rw------- 1 pmrauto pmrauto 0 2008-05-08 19:39 sess_vo3h33ovjqoa57t5s8jcs20lu1
-rw------- 1 planetauto planetauto 0 2008-05-09 09:37 sess_vo8pvqr2ao7sfoipsfs8k5r3r1
-rw------- 1 and and 22 2008-05-10 22:11 sess_vob53vqhuqrhold1c1s78vjdm6
-rw------- 1 profilcar profilcar 0 2008-05-10 01:59 sess_vobtojukm1bkgihsd1cnuliq26
-rw------- 1 cnamont cnamont 22 2008-05-12 18:54 sess_voi1scgj3sjcp407iv7n07to37
-rw------- 1 renlannion renlannion 0 2008-05-09 17:43 sess_vojjvqgle8mfg3ru2hd61a5et3
-rw------- 1 autbonplan autbonplan 353 2008-05-12 02:13 sess_vokln0jtkrr0mgclgfcokerpk3
-rw------- 1 drochon drochon 19 2008-05-12 20:22 sess_vokpse2l2o2rfnadunqo40gk31
-rw------- 1 planetauto planetauto 0 2008-05-09 09:19 sess_vom78k9auu703e1ne44i9v6271
-rw------- 1 renlannion renlannion 0 2008-05-09 19:36 sess_vonhlqri8k60m7516874odjlo5
-rw------- 1 rhinrhone rhinrhone 0 2008-05-12 16:03 sess_voqguv3id4pih98u9n12d89bv3
-rw------- 1 autbonplan autbonplan 30 2008-05-11 22:50 sess_vp8jn4vb8lvi9jqbsgqhotmkm6
-rw------- 1 pmrauto pmrauto 0 2008-05-12 03:33 sess_vp9frlj411p10voqj7gdra9js4
-rw------- 1 challenge challenge 22 2008-05-07 10:06 sess_vpi4onod86gqbovijar7ufcut4
-rw------- 1 surpluauto surpluauto 0 2008-05-12 12:47 sess_vpjikbqsq0f9bugj5sqgei8lk4
-rw------- 1 evenvo evenvo 0 2008-05-12 14:08 sess_vpkapi8r30k9ulflpena6hsqm4
-rw------- 1 pmrauto pmrauto 0 2008-05-11 17:48 sess_vpl1s8h80a80h2cgaqdaqcq010
-rw------- 1 rhinrhone rhinrhone 285 2008-05-07 11:09 sess_vprcbjah0h6i39pev6tat2hbb1
-rw------- 1 renlannion renlannion 0 2008-05-10 02:41 sess_vq1djj9ad62b96a2t8dlu0t0q5
-rw------- 1 accelauto accelauto 0 2008-05-10 13:00 sess_vq1m1e2e5sgp4eagbfbuu13fu1
-rw------- 1 loireauto loireauto 0 2008-05-10 18:31 sess_vq47tqtaljs9uq2t82o5oshce5
-rw------- 1 renlannion renlannion 0 2008-05-12 04:22 sess_vq53m70rrpgk4t89qar2lpfn35
-rw------- 1 autbonplan autbonplan 30 2008-05-12 17:13 sess_vq606hau16vh8p324r2u9kj4t1
-rw------- 1 and and 22 2008-05-06 12:35 sess_vq9m6sl3qr7b32v4bs7fqdekc1
-rw------- 1 surpluauto surpluauto 0 2008-05-07 04:07 sess_vqnm9iphvt5q0ct4s50qjrf0v3
-rw------- 1 aa31 aa31 0 2008-05-11 18:06 sess_vqpe8pujv9hvnbk618ja1k9ij5
-rw------- 1 fourchene fourchene 0 2008-05-09 08:07 sess_vqq19sk7qh61nchl5crrf1vf10
-rw------- 1 espaceauto espaceauto 22 2008-05-09 19:03 sess_vqs13ebaois4r0dglegv3q0ir5
-rw------- 1 acrauto acrauto 124 2008-05-08 20:43 sess_vqunkhb8c1o99dlodjpubm4256
-rw------- 1 profilcar profilcar 17 2008-05-06 17:08 sess_vr08topsgdnunb1fge09uojoo2
-rw------- 1 accelauto accelauto 0 2008-05-10 11:58 sess_vr3jrus3piv16294k0qi35rqm0
-rw------- 1 adxauto adxauto 0 2008-05-11 14:11 sess_vra6381nno4dr7vkd747nnd7r3
-rw------- 1 pan44 pan44 0 2008-05-07 18:05 sess_vratj2jcm7p9295ho3t2qusg56
-rw------- 1 surgerutil surgerutil 29 2008-05-08 13:05 sess_vrbhr87ab0g1qvcda1ec6sdpd3
-rw------- 1 aa31 aa31 81 2008-05-10 01:09 sess_vrl13qr28ckjrgblijjdibtra1
-rw------- 1 loireauto loireauto 0 2008-05-12 09:51 sess_vromfc45u2svrnrpn7ku3m2m13
-rw------- 1 surpluauto surpluauto 0 2008-05-12 12:45 sess_vrs79ovj1qg8s3pr109ogvn1i7
-rw------- 1 tierce tierce 21 2008-05-12 11:04 sess_vs07a7rbj0hp2qlf6fbdu8vp12
-rw------- 1 mionscar mionscar 0 2008-05-12 16:39 sess_vs0fnuqrrm73488m0gu3fi6uu7
-rw------- 1 pmrauto pmrauto 0 2008-05-11 07:42 sess_vs0uanjmf2usngspa5v9gvru04
-rw------- 1 hexagauto hexagauto 26 2008-05-07 13:00 sess_vs96m9rl3m6bd5ukmq816r24c6
-rw------- 1 autbonplan autbonplan 30 2008-05-12 16:24 sess_vsagoeh6cgkgeesrca3likgfn5
-rw------- 1 loireauto loireauto 35 2008-05-12 09:51 sess_vsb6pgchjc1mje0elv6pf9p530
-rw------- 1 aa31 aa31 0 2008-05-12 02:10 sess_vsbqrbsrn6o7lg2j796a9ilcs2
-rw------- 1 autbonplan autbonplan 0 2008-05-10 23:28 sess_vse8rq0hbsmd4t8t23rhr66p66
-rw------- 1 mda mda 0 2008-05-11 21:36 sess_vsj2e74g4cvsrmhjgs54fooup4
-rw------- 1 pan44 pan44 0 2008-05-12 05:17 sess_vsm2rfh3b4mlhr6bautvslf2n7
-rw------- 1 accelauto accelauto 0 2008-05-08 22:57 sess_vspfflt1o6d4gnutcflt7ev6b6
-rw------- 1 surpluauto surpluauto 0 2008-05-06 09:08 sess_vsr5q3oh0u0jff4rrlo7691g84
-rw------- 1 villeneuve villeneuve 22 2008-05-11 19:59 sess_vsu95pcfhdt6gasnen4dutidh4
-rw------- 1 espaceauto espaceauto 22 2008-05-11 14:11 sess_vt015654dn7uddr5u1sce2ldu1
-rw------- 1 chanasauto chanasauto 55 2008-05-12 10:17 sess_vt1tvv844du0v93g0sbiubma97
-rw------- 1 bmcauto bmcauto 0 2008-05-10 14:42 sess_vt2jo0cujcetp31l4rusbhls33
-rw------- 1 planetauto planetauto 22 2008-05-10 13:52 sess_vtn41ovelmd6rd6cjqqdifjn70
-rw------- 1 bjhauto bjhauto 0 2008-05-12 20:10 sess_vtp8vh9h0nfqetios7niiq30b0
-rw------- 1 acstarter acstarter 0 2008-05-12 07:43 sess_vtqv6jjvvh5js9c5h1n0km3bu7
-rw------- 1 renlannion renlannion 0 2008-05-08 13:49 sess_vtrv8rhuv4dvem2m8qhl5qard6
-rw------- 1 pan44 pan44 0 2008-05-11 08:04 sess_vtvfqqftdgse11vg3gt5v1fqg6
-rw------- 1 aa31 aa31 81 2008-05-07 16:43 sess_vu3b0m9gnpgpqt86ghj1eoi2s2
-rw------- 1 rhinrhone rhinrhone 582 2008-05-06 18:08 sess_vu4ub54cqu5ejirnicb4tfs9q3
-rw------- 1 groupe3b groupe3b 25 2008-05-08 06:37 sess_vu5lu9qaaaq6v5r0uspqnrkc83
-rw------- 1 and and 0 2008-05-09 16:46 sess_vu6jigmrfn6ska2m44g8f9ik85
-rw------- 1 acstarter acstarter 0 2008-05-09 10:36 sess_vu6sn1klh43uakh9nhj1cfoub0
-rw------- 1 aa34 aa34 799 2008-05-12 14:25 sess_vu7mc9fg3vicv4hdhuoa9t4hm7
-rw------- 1 fourcadier fourcadier 22 2008-05-12 20:08 sess_vu9ea6qehqv82556h935opfc97
-rw------- 1 espaceauto espaceauto 0 2008-05-10 19:03 sess_vug7ir071hg251qeok1maclus7
-rw------- 1 acrauto acrauto 22 2008-05-07 19:23 sess_vuiaed7ellcule41vcr03134v2
-rw------- 1 aa31 aa31 80 2008-05-11 21:51 sess_vulch39dig8545s4k7290q3b92
-rw------- 1 autbonplan autbonplan 30 2008-05-12 18:58 sess_vum6sak8eq5jnvqv2mqsi33s03
-rw------- 1 tierce tierce 630 2008-05-12 20:34 sess_vun8a2n9hpgjdmirf8nhpohhv5
-rw------- 1 fpa fpa 550 2008-05-11 23:21 sess_vutkgfus1lpulm6ao43dpkfup1
-rw------- 1 abmotors abmotors 492 2008-05-11 12:46 sess_vutrtlbf4u4rqcam8u05qpbrb7
-rw------- 1 profilcar profilcar 0 2008-05-09 01:43 sess_vuu8usvu93l7o8b25tu1b0knk0
-rw------- 1 autbonplan autbonplan 149 2008-05-12 19:58 sess_vuv3k00f51bi2lo8hbea0gkav6
-rw------- 1 profilcar profilcar 25 2008-05-11 19:37 sess_vv2al5h6hf7p8qv442863hqs65
-rw------- 1 aa31 aa31 0 2008-05-08 18:18 sess_vv2c5q9ej8r8vkk65moaea2gn4
-rw------- 1 rhinrhone rhinrhone 0 2008-05-10 18:55 sess_vv2qge3vibj9nia7eu1sj0fel1
-rw------- 1 mda mda 22 2008-05-12 17:07 sess_vv32ae2ukm0k43tsg2gte9jua5
-rw------- 1 pmrauto pmrauto 0 2008-05-11 07:23 sess_vv6duae6gu87144mdahookuk76
-rw------- 1 pouliquen pouliquen 0 2008-05-09 18:32 sess_vvaakuskirje06tjv22j8qj4k5
-rw------- 1 surpluauto surpluauto 0 2008-05-08 17:14 sess_vvbggobr1lb8eu6t10kgqvccr6
-rw------- 1 franceutil franceutil 0 2008-05-12 17:25 sess_vvcv58oavn4hsnrc1c6n1psvk2
-rw------- 1 loireauto loireauto 0 2008-05-12 14:18 sess_vvfcmddulpam4qn6d86ghv6rh2
-rw------- 1 aa31 aa31 17 2008-05-07 14:47 sess_vvgk56le15km6evndf5893df57
-rw------- 1 autbonplan autbonplan 238 2008-05-12 08:40 sess_vvo3cm28q9ddtjtsfuce9h1153
-rw------- 1 pmrauto pmrauto 0 2008-05-12 14:30 sess_vvr16mg8705bsth0mtpudutrj1
-rw------- 1 autofrance autofrance 22 2008-05-06 09:30 sess_vvuqc2b8kn1av2usu3n4s8ub53
-rw------- 1 webapps webapps 16909 2008-05-10 14:58 sess_W823VMaNtOGo6YRA9t3iTejNSwb
-rw------- 1 webapps webapps 16917 2008-05-10 16:45 sess_Y2q5SrsjhC7JztXVQR7VVxD-iQd
Please any help is welcomed...
I wish that sessions remain in tmp as before, but need that they get purged automatically and that webapps can access session information...
Yours
Tdldp
