Disk Usage in Directadmin
j531168
The "Disk Usage" shown in the DA system is never corrected.
How can I update the information?
I have tried
"echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue"
and
"/sbin/quotaoff -a; /sbin/quotacheck -avugm; /sbin/quotaon -a;"
already.
  • cd /usr/local
  • chown -R diradmin directadmin/
  • echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
I've tried
"/usr/sbin/repquota /home > /home/tmp/quota-dump"
but it said
"repquota: Mountpoint (or device) /home not found.
repquota: Not all specified mountpoints are using quota."
Please show the output of the command I show you then I will advice you.
Please note that I am not responsible if anything goes wrong with your server
I've tried
that will say, you do not have any partition mounted on /home
try to replace '/home' with '/'
do you have any tmp directory in de /home directory?
if not try to run:
mkdir /home/tmp
chmod 777 /home/tmp
when done rerun the tally...
if not try to run:
mkdir /home/tmp
chmod 777 /home/tmp
this time, I tired "/usr/sbin/repquota / > /home/tmp/quota-dump"
it'ok now. But what should I do next ?
repquota is only beeing used to show the usage / quota of a user, noting more.
Have you checked there is a tmp directory in the /home ?
The directory has to be world wide readable and writable (777).
Check if it is correct.
Also you didn't chow the output of the command:
"/usr/sbin/repquota /"
