 on each server?
 on each server?
Added to versions, ability to hide the number of users.
http://www.directadmin.com/features.php?id=876
Thanks, John.
I suppose I should add that I was intentionally exagerating. While DirectAdmin might be able to host 22,000 domains per server with judicious modifications to the kernel, lots of memory, lots of cores, apache 2 and some changes to how apache handles error logs, I don't recommend it and I don't support it (and I don't think John and Mark do, either).
 Seriously though we've gone and made super sized VPS nodes, with then small VPSes for shared/reseller hosting.  Making the VPSes much smaller (say limiting to 100 accounts) is much easier to manage.  Blacklisted IPs, CPU load, hacked accounts, etc..
  Seriously though we've gone and made super sized VPS nodes, with then small VPSes for shared/reseller hosting.  Making the VPSes much smaller (say limiting to 100 accounts) is much easier to manage.  Blacklisted IPs, CPU load, hacked accounts, etc.. and now uses Cobalt RaQ2s.
 and now uses Cobalt RaQ2s. ; but the same concepts apply.
; but the same concepts apply.Which VPS do you use? We're going to start experimenting later this year.
Yes, still visible from Admin Level -> IP Manager.
