vm-Pop3d 1.1.7f-DA-2 ***stopped***
designpc
I have recently moved from one DA server to another.
The old had v1.31, and the new server is running v1.32
In the System information bit on the new server it says:
However on the old server is says:
dovecot 1.0.3 running
Now I can get IMAP mail fine, haven't test POP3 yet, so I was wondering how do I change this bit above to "running"
Here is my ps -A output if it helps:
# ps -A
  PID TTY          TIME CMD
    1 ?        00:00:00 init
 1436 ?        00:00:00 named
 1604 pts/0    00:00:00 mysqld_safe
 1624 pts/0    00:00:00 mysqld
 1626 pts/0    00:00:00 mysqld
 1627 pts/0    00:00:00 mysqld
 1628 pts/0    00:00:00 mysqld
 1629 pts/0    00:00:00 mysqld
 1630 pts/0    00:00:00 mysqld
 1631 pts/0    00:00:00 mysqld
 1632 pts/0    00:00:00 mysqld
 1634 pts/0    00:00:00 mysqld
 1635 pts/0    00:00:00 mysqld
 3240 ?        00:00:00 xinetd
 5696 ?        00:00:00 miniserv.pl
11624 ?        00:00:00 imap-login
11625 ?        00:00:00 imap-login
11628 ?        00:00:00 imap-login
11651 ?        00:00:00 imap-login
11659 ?        00:00:00 imap-login
11668 ?        00:00:00 imap-login
11671 ?        00:00:00 imap-login
11811 ?        00:00:01 sshd
11813 ?        00:00:00 sftp-server
13381 ?        00:00:00 imap
13382 ?        00:00:00 imap-login
13592 ?        00:00:00 directadmin
13733 ?        00:00:03 sshd
13736 pts/0    00:00:00 bash
14107 ?        00:00:00 syslogd
14316 ?        00:00:00 crond
15445 ?        00:00:00 sshd
15447 ?        00:00:00 sftp-server
15880 ?        00:00:00 proftpd
15984 ?        00:00:00 httpd
16018 ?        00:00:00 sshd
16019 ?        00:00:00 httpd
16020 ?        00:00:00 httpd
16021 ?        00:00:00 httpd
16022 ?        00:00:00 httpd
16023 ?        00:00:00 httpd
17720 ?        00:00:00 da-popb4smtp
18359 ?        00:00:00 dovecot
18360 ?        00:00:00 dovecot-auth
20014 ?        00:00:00 pop3-login
20015 ?        00:00:00 pop3-login
20016 ?        00:00:00 pop3-login
20037 ?        00:00:00 pop3-login
20038 ?        00:00:00 pop3-login
20039 ?        00:00:00 pop3-login
20040 ?        00:00:00 pop3-login
20041 ?        00:00:00 pop3-login
20042 ?        00:00:00 pop3-login
20043 ?        00:00:00 pop3-login
20056 ?        00:00:00 pop3-login
20057 ?        00:00:00 pop3-login
20058 ?        00:00:00 pop3-login
20059 ?        00:00:00 pop3-login
20060 ?        00:00:00 pop3-login
20061 ?        00:00:00 pop3-login
20062 ?        00:00:00 imap-login
20064 ?        00:00:00 imap-login
20065 ?        00:00:00 imap-login
20067 ?        00:00:00 imap-login
20068 ?        00:00:00 imap-login
20069 ?        00:00:00 imap-login
20089 ?        00:00:00 imap-login
20097 ?        00:00:00 imap-login
25663 ?        00:00:00 sshd
26135 pts/1    00:00:00 bash
28433 ?        00:00:00 directadmin
28434 ?        00:00:00 directadmin
28445 ?        00:00:00 directadmin
29767 ?        00:00:00 exim
29774 ?        00:00:00 spamd
29780 ?        00:00:00 spamd
29781 ?        00:00:00 spamd
29830 ?        00:00:00 httpd
30336 ?        00:00:00 directadmin
30353 ?        00:00:00 directadmin
31836 pts/0    00:00:00 ps
And here is netstat -l
# netstat -l
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address               Foreign Address             State
tcp        0      0 *:ftp                       *:*                         LISTEN
tcp        0      0 1.1.1.1:domain        *:*                         LISTEN
tcp        0      0 my.domain.com:domain    *:*                         LISTEN
tcp        0      0 localhost:domain            *:*                         LISTEN
tcp        0      0 *:smtp                      *:*                         LISTEN
tcp        0      0 localhost:rndc              *:*                         LISTEN
tcp        0      0 *:imaps                     *:*                         LISTEN
tcp        0      0 *:pop3s                     *:*                         LISTEN
tcp        0      0 *:mysql                     *:*                         LISTEN
tcp        0      0 *:submission                *:*                         LISTEN
tcp        0      0 *:rockwell-csp2             *:*                         LISTEN
tcp        0      0 *:pop3                      *:*                         LISTEN
tcp        0      0 localhost:783               *:*                         LISTEN
tcp        0      0 *:imap                      *:*                         LISTEN
tcp        0      0 *:ndmp                      *:*                         LISTEN
tcp        0      0 *:6363                      *:*                         LISTEN
tcp        0      0 *:https                     *:*                         LISTEN
tcp        0      0 *:http                      *:*                         LISTEN
udp        0      0 *:ndmp                      *:*
udp        0      0 1.1.1.1:domain        *:*
udp        0      0 my.domain.com:domain    *:*
udp        0      0 localhost:domain            *:*
udp        0      0 *:41061                     *:*
udp        0      0 *:41062                     *:*
Active UNIX domain sockets (only servers)
Proto RefCnt Flags       Type       State         I-Node Path
unix  2      [ ACC ]     STREAM     LISTENING     7880364 /tmp/ssh-rUqBl13733/agent.13733
unix  2      [ ACC ]     STREAM     LISTENING     8432745 /var/run/dovecot/dict-server
unix  2      [ ACC ]     STREAM     LISTENING     8432747 /var/run/dovecot/login/default
unix  2      [ ACC ]     STREAM     LISTENING     8432755 /var/run/dovecot/auth-worker.18360
unix  2      [ ACC ]     STREAM     LISTENING     8188985 /var/lib/mysql/mysql.sock
unix  2      [ ACC ]     STREAM     LISTENING     8083001 /tmp/ssh-yfuOx25663/agent.25663
Has your new server been converted to Dovecot/Maildir yet? If not, convert it.
Hi Jeff,
Yes Dovecot is installed, I have just checked. What is there to use other than Dovecot, I can't remember what the old one was..? Didn't it use .mbox..?
Edit /usr/local/directadmin/data/admin/services.status and remove vm-pop3d line.
