mysql database users not stored in Backups
SupermanInNY
Hi All,
I have an old server running with WhiteBox 3 and is intended to be retired.
It is running mysql 5.0.45 and apache 1.3.41 with PHP4.4.7.
It is running with DA 1.31.4
I have a new server that I've just setup, fresh install of everything:
CentOS 5.0 i386
It is running mysql 5.0.45a and apache 1.3.41 with PHP4.4.8
It is running with DA 1.32.1
When I'm creating the Reseller's backup it creates a backup with the database, but when I try to restore it, it doesn't create the Database Users.
I've tried to load the backup and restore it onto a diff server (running with mysql 4.1).
I get the same result of No Database users created.
Any pointers?
-Alon.
I've replied to your email, see if the binaries I've sent you help at all. Let me know if they don't. I may need to take a look to figure it out.
RESOLVED
Thanks to John of DA the issue has bee identified and resolved.
The problem was with the MySQL database.
John checked the mysql err log and found:
080622 21:11:21 [Warning] mysql.user table is not updated to new password format; Disabling new password usage until mysql_fix_privilege_tables is run
The fix for this kind of problem is simple:
mysql_fix_privileges_table --user=da_admin --password=daadminpass
(The value for the daadminpass is located at: /usr/local/directadmin/conf/mysql.conf
Thanks John and Hopefully this will help someone else down the road.
-Alon.
also stuck
Hhmmm, same problem here. I urgently needed to move server. MySQL users and databases are not restored from the backup :mad:
Unable to restore database user1_mail.sql to user1_mail : ERROR 1045 (28000): Access denied for user 'user1'@'localhost' (using password: NO)
Unable to restore database user1_menu.sql to user1_menu : ERROR 1045 (28000): Access denied for user 'user1'@'localhost' (using password: NO)
I'm still looking into the problem....
RESOLVED
-Alon.
Where to write this?
Its obviously a command you have to run. If its not that obvious to you then you should probably get someone to help you with server administration.
