I don't understand, but maybe is my english...I already explained why email may be considered spam; more below.
None has the possibility to install any software on server, all user must use exim for sending email.Yes, If someone installs their own software to send email, and doesn't use exim, it won't appear in the exim logs.
If use their own software on their local pc, they can't use the server's account, but only the domain's address... In this case, what spamblocker report for block? Domain or Ip address of domain?
In particular one of my user, use own mail server as MX record...
This is their configuration of DNS for USERDOMAIN on my SERVER:
x.x.x.x is My server IP
y.y.y.y and z.z.z.z is their 1st and 2nd mail server
They want to have the complete control of their mailserver because in the past they have had some problem with their hoster...ftp A x.x.x.x
USERDOMAIN.it. A x.x.x.x
localhost A 127.0.0.1
mail A y.y.y.y
mail2 A z.z.z.z
pop A x.x.x.x
webmail A x.x.x.x
www A x.x.x.x
USERDOMAIN.it. NS ns1.SERVER.it.
USERDOMAIN.it. NS ns2.SERVER.it.
mail.USERDOMAIN.it. MX 10
mail2.USERDOMAIN.it. MX 20
USERDOMAIN.it. TXT "v=spf1 a mx ip4:x.x.x.x ?all"
If they send spam, which IP address is listed in the blacklist to block?
Keep in mind that they don't use my mailserver for send their email...
In the exact moment that I have received the mail delivery notification, I log into directadmin to see the /var/log/exim/mainlog file, but I see that there isn't the loggin of error while sending. After I see it, I resend the message and exim correctly log it!If you sent the email through your server the attempt should appear in your /var/log/exim/mainlog file. You can always tail the file in realtime while sending the mail to see if your server is logging it properly.
And is it a problem? Why the other disconnect me?Because the other end disconnected you.
You intend to say that the process ends with an error or may be a normal thing?
