Email under subdomain
ho-kia
can i create an email under subdomain ?
ex :
domain : beach.com
subdomain : lay.beach.com
then I want to create email with address [email protected]
can i ? if can, how ? i can't find how to set.
2nd. I create autoresponder, can i make in html code? i try, but it will send all the html source code.
1) yes, you just create the subdomain as another domain in your account. New domain: sub.domain.com. DA doesn't know the difference and it should work fine.
2) I don't believe it can be done with the current setup. I think you need to add special headers into the email, which could only be done by changing exim itself (unless there is a way to send the content type without a header, but I don't think there is)
I am trying to create [email protected] too, but it is not working right for me.
Currently my MX for domain.com is set to a 3rd party email filtering company. If i send email to [email protected], i'll get a NDR "Unknown User".
Anybody has any success?
Thanks.
You should probably ask for help from the third-party email filtering company; it would be hard for us to guess what an unnamed company is doing to check for the username before accepting email.
