Algorithms
- Aug 31, 2005
This is currently deployed on our DA server.
This assumes you have the ports collection installed.
Comments, Suggestions, Improvements welcomed.
Green text is commands and output from the console
Orange-red text is for log and error information
Dark blue is for file contents
I recently upgraded from Apache 1.3.x and mod_python 2.7 to Apache 2.0.59 and mod_python 3.2.8. Here is an update to my old HOWTO
This is how I did it on FreeBSD 5.3-RELEASE
First we need a fresh build of Python without thread support. If you tried to install mod_python previously and got a message like this.
Cannot load /usr/lib/apache/mod_python.so into server:
/usr/lib/apache/mod_python.so: Undefined symbol "pthread_attr_init"
That means the Python you compiled mod_python against had threads enabled. To fix this, we need to edit our Python port and reinstall. Make sure to cvsup your ports collection before installing the new Python.
$ cd /usr/ports/lang/python
$ su
$ make clean
$ WIHTOUT_THREADS=1 make install
$ exit
Note: You may need to run a make deinstall before running make install.
Once Python is installed without threads, you can test by running the shell and attemping to import thread, you should get an error.
$ python
Python 2.4.3 (#2, Sep 18 2006, 11:42:14)
[GCC 3.4.2 [FreeBSD] 20040728] on freebsd5
Type "help", "copyright", "credits" or "license" for more information.
>>> import threads
Traceback (most recent call last):
File "<stdin>", line 1, in ?
ImportError: No module named threads
Now we can install mod_python. Download and extract the mod_python 3.2.8 source.
$ cd ~/
$ fetch "http://mirror.candidhosting.com/pub/apache/httpd/modpython/mod_python-3.2.8.tgz"
$ tar -zxvf mod_python-3.2.8.tgz
$ cd mod_python-3.2.8
$ ./configure
$ make
$ su
$ make install
Now we have the mod_python module installed without threads and we are able to restart apache, but first we need to comment out the mod_python line in the httpd.conf
$ vi /etc/httpd/conf/httpd.conf
LoadModule python_module /usr/lib/apache/mod_python.so
Uncomment or add this line if you don't have it. Save and exit.
I logged in to DA as admin and restarted the httpd service that way. I prefer that over doing it in the shell.
Now, go to the directory where you want to use mod_python and create a .htaccess file
$ cd /home/user/domains/test.com/public_html
$ vi .htaccess
In that file, place the following lines. (Alter to fit your needs)
AddHandler mod_python .py
PythonHandler mod_python.publisher
PythonOption session DbmSession
PythonOption session_dbm /home/user/domains/test.com/session.dbm
PythonOption ApplicationPath /
PythonDebug On ## Turn this off when done with debugging
DirectoryIndex index.py
Now you can create a test file in the directory. Mine looked like this.
## index.py
from mod_python import apache
def index(req):
req.content_type = 'text/plain'
req.write('Hello from mod_python\n')
return apache.OK
Pull this up in your browser, if you see the works Hello from mod_python followed by a zero (0) you have successfully installed mod_python.
Enjoy
