Download with PHP problem
sky
Hello all.
I have 2 servers up to date and there is the same problem on both, and not only for me, but for all people and all Browser (just stoping the usual questions :))
The problem ?
When i download a file from this adress : http://www.graphiks.net/projets/myPHPupload/details/b978d88e-ad4b-4ee2-ad36-873e2cb0b38e (updated link (2))
while it is downloading, i cant clic on another link untill the download is over.
I try on another serveur the same script, and i can visit the website while im downloading.
This did not happen before ... i dont know when before whas :)
Have you got a idea from where the problem comes from ?
Edit : i forgot the server specs :
Os : fedora core 6
Installed version of PHP (CLI): 5.2.6
Installed version of Apache: 2.2.9
Installed version of ProFTPD: 1.3.1
Installed version of autoconf: 2.61
Installed version of automake: 1.10.1
Installed version of libtool: 2.2.4
Installed version of PCRE: 7.7
Installed version of curl: 7.18.2
Installed version of dovecot: 1.0.14
Installed version of MySQL: 5.0.51a
Installed version of Zend Optimizer: 3.3.3
Latest version of DA
Thx,
Sky
Ps : The title of the topic should be : Download with PHP problem and not Download width PHP problem.
I fixed the title for you.
Good question. I see the same issue using Linux/FireFox2.
I wonder if the issue is a setting in your version of Apache?
Hello
Well, it can be i suppose, but i have not change it much at all.
If you whant ... (and have the time :)) i can let you have a look.
Im looking around, but i seem to be the only one ^^
Sky
Hello again,
I just tried rebuilding the apache conf with :
./build rewrite_confs
But, still the same (i restarted apache after)
I dont understand whats whrong ... its strange.
Sky
I have also re built apache... and still no change.
Perhaps its a problem with PHP ... my code, or php.ini ?
Is there a limitor in php.ini that could do this ?
Sky
I have now tested with another code for download, and still the same result.
I updated all per packages.
dont now what to do more ...
Sky
Hello again.
Well, i left this problem aside a while, but it is a real pain :)
So, here are the facts :
A link to download : (i dont whant this page to be indexed, pm if you have a idea)
The code that downloads :
PHP:
            header('Content-Description: File Transfer');
            header('Content-Type: application/octet-stream');
            header('Content-Disposition: attachment; filename='.basename($File->file_realname));
            header('Content-Transfer-Encoding: binary');
            header('Expires: 0');
            header('Cache-Control: must-revalidate, post-check=0, pre-check=0');
            header('Pragma: public');
            header('Content-Length: ' . filesize($urlFichier));
            ob_clean();
            flush();
            readfile($urlFichier);
            exit;
So, when you download that file, try to navigate at the same time on the website...
Thx for any ideas ... i dont understand at all...
And, its the same on the 3 DA servers whe have.
I have the impression that the server does not allow 2 php threads from the same connexion... is that possible ?
Thx,
Sky
Well, i have found something ...
When i add a session_destroy() juste before the download code ... it works fine.
I you know why ... strange i find.
Sky
Sky
Apparently you can only have one connection at a time with sessions. I've read before about someone having a similar problem, but with database connections.
