Webalizer don't update!
spirit
Germany - Bremen
For two weeks i enabled Awstats and Disabled Webalizer.
For two days ago i enabled Webalizer aggain! Webalizer don't update anything anymore.
Awstats works fine!
Someone no why?
Output from #webalizer:
[root@server~]# webalizer
Webalizer V2.01-10 (Linux 2.6.18-53.1.21.el5) English
Using logfile STDIN (clf)
Creating output in current directory
Hostname for reports is 'host.hostname.com'
History file not found...
crond works also without any problem.
Check /usr/local/directadmin/conf/directadmin.conf if you have webalizer=1 and awstats=0, restart directadmin after the changes. Run tally now:
echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
/usr/local/directadmin/dataskq d
If you think that you have a problem with cron daemon: http://help.directadmin.com/item.php?id=107
