floyd
- Mar 29, 2005
Let's go back to your original suggestion:
If you have an issue with MySQL then you need to reinstall MySQL not DirectAdmin. The is true of other individual pieces of software, apache, bind, exim just to name a few.
Later you said:
Then that would make your server virtually unusable. The only things left would be the base install of the OS and the data.
If you really want to keep your data and reinstall DirectAdmin then the best thing to do is to use the backup feature in DA and format and reinstall everything fresh. That is the best scenario if you don't have the experience to figure out what the real problem is.
Optionally you could back up the data and then reinstall DA, without uninstalling. This will wipe out the current DA settings and you will have to restore from the backups you made.
The feature for which you are asking, uninstall DA and everything it installs, is similar to wanting the OS to be uninstalled but leave the data. Both are drastic last resort measures.
The same is true of wanting to uninstall and reinstall DA.
Apparently smtalk was able to fix the real problem without taking any of these drastic measures. I believe that was your real goal. And that is the mark of an experienced user.
The only time you have to reinstall a piece of software is if something really got screwed up. Maybe something did. And if something happened to DA itself maybe the feature we should be asking for is the ability to replace the DA system files with affecting the users data within DA. We may already have that, I don't know.
I am just stating the facts. If I am wrong then somebody more experienced can state what the facts are.
What do I know. I only joined in March 2005 and was a server admin for 6 years before that.
Id like to be able to uninstall DirectAdmin if there are any issues like MySQL not working or anything else. Or if you have issues during installation.
Later you said:
The uninstall would remove all things installed
Simply stating reformat shows an inexperienced user.
