principino1984
- Oct 10, 2008
Hi, I have this problem.
Tonight I had my httpd stopped because of this errors:
If I try to restart httpd from DA I get this error:
sbin/service httpd restart 2>&1
while if I try to start it from shell I get this error:
Syntax error on line 29 of /etc/httpd/conf/httpd.conf
Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
This is the lines:
<Limit GET POST OPTIONS PROPFIND>
Order allow,deny
Allow from all
</Limit>
what can be the problem?
thanks
Marco
[Wed Oct 29 00:10:01 2008] [notice] SIGHUP received. Attempting to restart
[Wed Oct 29 00:10:02 2008] [warn] RSA server certificate CommonName (CN) `www.tradeshell.it' does NOT match server name!?
[Wed Oct 29 00:10:02 2008] [warn] Init: SSL server IP/port conflict: www.xxx.it:443 (/usr/local/directadmin/data/users/xxx/httpd.conf:43) vs. www.yyy.it:443 (/usr/local/directadmin/data/users/yyy/httpd.conf:43)
(/usr/local/directadmin/data/users/zzz/httpd.conf:43) vs. www.yyy.it:443 (/usr/local/directadmin/data/users/yyy/httpd.conf:43)
[Wed Oct 29 00:10:02 2008] [warn] Init: SSL server IP/port conflict: www.luiginterlandi.it:443 (/usr/local/directadmin/data/users/qqq/httpd.conf:43) vs. www.yyy.it:443 (/usr/local/directadmin/data/users/yyy/httpd.conf:43)
[Wed Oct 29 00:10:02 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
This is the lines:
Order allow,deny
Allow from all
</Limit>
thanks
Marco
