where the mails gone ?
ben29
Israel
Try installing them (DA checks if the directory exists, and if it does - shows an URL):
./build squirrelmail
./build roundcube
./build uebimiau
./build atmail
./build roundcube
./build uebimiau
./build atmail
i did that
but after 1 min they gone
check both directadmin.conf's.......... I have 2, one in conf/ and one in templates/
/usr/local/directadmin/data/templates/directadmin.conf
/usr/local/directadmin/conf/directadmin.conf
nope, both files contains no hide_webmail_links line, and this problem only occur on some of my servers, not all of them, DA is the latest version. can't figure out why.
safe_mode may cause that
My webmail had gone after I modified the php.ini file as safe_mode = On. When I remodified php.ini file as safe_mode = Off webmail links came back.
Not: Changing php.ini file requires restart.
