Default cutom pages
WHI
I would like to use my own default index.html when I create a new account. How can I do this? I edited the /domains/default/index.html but, nothing happened.
I edited the usr/local/directadmin/data/templates/default/index.html and nothing happened too.
Could somebody help me?
Delete the reseller and readd them. Or edit the index.html in the resellers data folder.
I edited the index.html in the default folder of reseller.
What happened the sites I f I delete the reseller? Because I create some domain already.
Strange I dont see it in the reseller folder maybe it is a serverwide thing and not reseller based. But anyways after creating your custom template it will only work when you add new accounts.
Deleting the reseller and re-adding it isn't necessarily an option if you've already got domains under it.
If you already have domains then you need to manually move copies of the added/edited file(s) to each already existing domain.
