A AxlF Verified User Joined Dec 14, 2007 Messages 86 Nov 27, 2008 #1 Hi, if I click on Code: Admin > Server Stats > Server History the result is: Code: Error: document not found All stats at the reseller or user level are working. What is wrong with this? Regards, AxlF
D Dravu Verified User Joined Sep 9, 2007 Messages 293 Nov 27, 2008 #2 When did you start using Directadmin? You may have to wait until December as the information has to be tallied up at the end of each month and put into the Server History.
A AxlF Verified User Joined Dec 14, 2007 Messages 86 Nov 28, 2008 #3 I started using it in Jan 08... I think there should be already something...
D Dravu Verified User Joined Sep 9, 2007 Messages 293 Nov 28, 2008 #4 AxlF said: I started using it in Jan 08... I think there should be already something... Click to expand... Ah. There's a problem then. Have you tried contacting support[at]directadmin.com? You might get a faster and more accurate response.
D Danijell Verified User Joined Apr 6, 2008 Messages 22 Location Serbia Nov 29, 2008 #5 Hi, Are you using marina skin ? Danijel,
