@how@
new update.
Webmin control panel 1.441
MySQL 5.1.29
phpMyAdmin 3.0.1.1
Wael
MySQL 5.1.29
phpMyAdmin 3.0.1.1
Wael
How can remove installed scripts? such as mrtg?
*/5 * * * * root /usr/local/mrtg-2/bin/mrtg /var/www/html/mrtg/core/mrtg.cfg
rm -rf /usr/local/mrtg-2/
rm -rf /var/www/html/mrtg/
update script not part from directadmin.com
update.script homepage http://tools.web4host.net/
**** USE IT YOUR OWN RISKS ****
GNU GENERAL PUBLIC LICENSE
Version 2, June 1991
Copyright (C) 2006,2007 Free Software Foundation, Inc.
51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
Everyone is permitted to copy and distribute verbatim copies
of this license document, but changing it is not allowed.
Update script made by Wael Isa
H188, R4008, Arad 240, Kingdom of Bahrain
http://www.web4host.net
Version: 1.3
Release Date: 1 / 9 / 2006
If you find update script useful, please consider to make a donation to support this freeware.
Please keep in mind that donations are welcome, but in no way required to use and distribute update.script.
donate via 2checkout.com & paypal accepted
update.script Version: 1.3
update script tested in this OS 32bit & 64bit.
- RedHat Linux 7.2, 7.3, 8.0, 9.0
- RedHat Fedora 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0
- RedHat Enterprise 3.x, 4.x, 5.x
- CentOS 3.x, 4.x, 5.x
- Please report about other OS to add here
and update to
- OpenSSL 0.9.8i (You need to build ssh, apache, php, etc after upgrade)
- Exim 4.69
- OpenSSH 5.1p1
- ProFTP 1.3.1
- phpMyAdmin 3.0.1.1
- MySQL 5.0.67 (You need to build php after upgrade)
- MySQL 5.1.29 (You need to build php after upgrade)
- ClamAV 0.94
- AVG 7.5 r51-a1243
- MRTG 2.16.2
- SquirrelMail 1.4.16
- SquirrelMail full language pack
- SpamAssassin 3.2.5
- IMAP 2004c1 (You need to build php after upgrade)
- MODsecurity 2.5.7 (Apache 2.x Only)
- MODsecurity 2.5.7 Rules
- MODsecurity 1.9.5 (Apache 1.x Only)
- MODsecurity 1.9.5 Rules
- MODevasive 1.10.1
- KISS My Firewall 2.2
- eAccelerator 0.9.5.3
- Freetype 2.3.7
- Webmin control panel 1.441 (You need to open one port 10000 in your firewall)
- Nobody Check Security Tool 1.03
Just download/chmod
Run this to read how to use.Code:mkdir /usr/local/updatescript cd /usr/local/updatescript wget http://tools.web4host.net/update.script chmod 755 update.script
Run this to update update.scriptCode:./update.script
Run this to see release date and versionCode:./update.script UPDATEME
Run this to clean update script folderCode:./update.script DATE
Code:./update.script CLEAN
Note:-
1- Run this to clean or update update script before you use
2- Select best mirror for your server mirror.conf , if you want new mirror.conf file just delete old one in update script folder.
ClamAV
beforeCode:nano -w /etc/exim.conf
addCode:primary_hostname =
afterCode:av_scanner = clamd:/tmp/clamd
addCode:check_message:
save then restart eximCode:deny message = This message contains malformed MIME ($demime_reason) demime = * condition = ${if >{$demime_errorlevel}{2}{1}{0}} deny message = This message contains a virus or other harmful content ($malware_name) demime = * malware = * deny message = This message contains an attachment of a type which we do not accept (.$found_extension) demime = bat:com:pif:prf:scr:vbs warn message = X-Antivirus-Scanner: Clean mail though you should still use an Antivirus
Code:/sbin/service exim restart
MODsecurity 2.x
afterCode:nano -w /etc/httpd/conf/httpd.conf
32bitCode:LoadModule php5_module /usr/lib/apache/libphp5.so
64bitCode:LoadFile /usr/lib/libxml2.so LoadModule security2_module /usr/lib/apache/mod_security2.so
and add this down in httpd.confCode:LoadFile /usr/lib64/libxml2.so LoadModule security2_module /usr/lib/apache/mod_security2.so
Code:<IfModule mod_security2.c> # ModSecurity2 ONLY # Do not change anything in included files # Include /etc/modsecurity2/modsecurity-rules-selected-by-web4host.net.conf </IfModule>Code:/sbin/service httpd restart
MODsecurity 1.x
addCode:nano -w /etc/httpd/conf/httpd.conf
Code:<IfModule mod_security.c> # Only inspect dynamic requests # (YOU MUST TEST TO MAKE SURE IT WORKS AS EXPECTED) #SecFilterEngine DynamicOnly SecFilterEngine On # Reject requests with status 500 SecFilterDefaultAction "deny,log,status:500" # Some sane defaults SecFilterScanPOST On SecFilterCheckURLEncoding On SecFilterCheckCookieFormat On SecFilterCheckUnicodeEncoding Off SecFilterNormalizeCookies On # enable version 1 (RFC 2965) cookies SecFilterCookieFormat 1 #SecServerResponseToken Off #If you want to scan the output, uncomment these #SecFilterScanOutput On #SecFilterOutputMimeTypes "(null) text/html text/plain" # Accept almost all byte values SecFilterForceByteRange 1 255 # Server masking is optional #fake server banner - NOYB used - no one needs to know what we are using SecServerSignature "Power MOD by web4host.net" #SecUploadDir /tmp #SecUploadKeepFiles Off # Only record the interesting stuff SecAuditEngine RelevantOnly #SecAuditLog logs/audit_log # You normally won't need debug logging #SecFilterDebugLevel 0 #SecFilterDebugLog logs/modsec_debug_log # Mini Rules Include /etc/modsecurity/mini.conf </IfModule>Code:/sbin/service httpd restart
MODevasive
Apache 1
Code:<IfModule mod_evasive.c> DOSHashTableSize 3097 DOSPageCount 2 DOSSiteCount 50 DOSPageInterval 1 DOSSiteInterval 1 DOSBlockingPeriod 10 DOSWhitelist 127.0.0.1 DOSEmailNotify [email protected] </IfModule>if did not work tryCode:/sbin/service httpd restart
then edit httpd.confCode:/usr/local/directadmin/customapache/
after thisCode:nano -w /etc/httpd/conf/httpd.conf
addCode:LoadModule perl_module /usr/lib/apache/libperl.so
after thisCode:LoadModule evasive_module /usr/lib/apache/mod_evasive.so
addCode:<IfDefine HAVE_PYTHON> AddModule mod_python.c </IfDefine>
Code:AddModule mod_evasive.cCode:/sbin/service httpd restart
Apache 2
Code:<IfModule mod_evasive20.c> DOSHashTableSize 3097 DOSPageCount 2 DOSSiteCount 50 DOSPageInterval 1 DOSSiteInterval 1 DOSBlockingPeriod 10 DOSWhitelist 127.0.0.1 DOSEmailNotify [email protected] </IfModule>Code:/sbin/service httpd restart
if you want do test you need to remove (DOSWhitelist) from httpd.conf
Code:wget http://tools.web4host.net/modevasive/test.txt mv test.txt test.pl chmod 755 test.pl ./test.pl
KISS My Firewall
Ready for Direct Admin & Plesk & Webmin & cPanel.
if you want use other SSH port just add in TCP_IN & TCP_OUT
Running anywhere on the command line, you simply type:
To stop the firewall, type:Code:kiss start
To get status information, type:Code:kiss stop
If you want to block an offenders IP address/subnet, simply edit the BLOCK_LIST variable in the /usr/bin/kiss file. You can separate IP addresses and subnet's with a space. Once you are finished, simply restart KISS by typing:Code:kiss status
Last, but not least, it is recommended that you configure the firewall to allow only for needed ports. Using trusted IP addresses/subnets is also recommended. These variables are located near the beginning of the /usr/bin/kiss file and are self-explanatory. Once you make changes, you should always restart KISS for the changes to take effect:Code:kiss restart
kiss restart
edit kiss and set what os you use
# Enabled this for Pre Fedora Core 2 or Red Hat
# Enabled this for Fedore Core 2 or laterCode:EXTN="o"
Code:EXTN="ko"
like CentOS use EXTN="ko" just remove # before EXTN="ko" then kiss start
eAccelerator
when done you see link look like
copy your like to add in php.ini
edit php.ini
add this after Windows Extensions , in the list down.Code:nano -w /usr/local/lib/php.ini
save and restart apacheCode:zend_extension="/usr/local/lib/php/extensions/no-debug-non-zts-20020429/eaccelerator.so" eaccelerator.shm_size="32" eaccelerator.cache_dir="/tmp/eaccelerator" eaccelerator.enable="1" eaccelerator.optimizer="1" eaccelerator.check_mtime="1" eaccelerator.debug="0" eaccelerator.filter="" eaccelerator.shm_max="0" eaccelerator.shm_ttl="0" eaccelerator.shm_prune_period="0" eaccelerator.shm_only="0" eaccelerator.compress="1" eaccelerator.compress_level="9"
Freetype
Note: no need to use if if you use custombuild, only how use customapache.
Apache 1Code:cd /usr/local/directadmin/customapache/
Apache 2Code:nano -w configure.php
replaceCode:nano -w configure2.php
byCode:--with-gd \ --with-gd-dir=/usr/local \
save then runCode:--with-gd \ --with-gd-dir=/usr/local/lib \ --with-freetype \ --with-freetype-dir=/usr/local/lib \
Apache 1Code:./build clean ./build gd
Apache 2Code:./build clean ./build gd ./build php d service httpd restart
Code:./build clean ./build gd ./build php_ap2 d service httpd restart
IMAP
Apache 1
addCode:nano -w configure2.php
afterCode:--with-imap=/usr/local/imap-2004c1 \
save then build php and restart apacheCode:--with-zip \
Code:service httpd restart
AVG Anti-Virus
Clean folder HOME (full)
clean folder HOME (without archives)Code:avgscan -clean -ext=* -rt -arc /home
Update AVG DBCode:avgscan -clean -ext=* -rt /home
Code:avgupdate --online /opt/grisoft/avg7/data
ill add more soon.
The Nobody Check tool is a new and unique security tool that can detect malicious processes that are running on your Linux server and report them to you in real time or by email. The tool can be configured to run at selected times and doesn’t eat up resources or interfere with server operations.
edit and set your email then save
editCode:nano -w /usr/local/nobody_check/nc.conf
addCode:nano -w /etc/crontab
saveCode:# nobody_check */15 * * * * root /usr/local/nobody_check/nobody_check >/dev/null 2>&1
Best Regards,
Wael Isa
A fix for MySQL 5.1 (32-bit) installation:
Code:cd /usr/local/updatescript perl -pi -e 's/\$MYSQL51.i386.rpm/\$MYSQL51.glibc23.i386.rpm/' update.script
Can I install IMAP 2004c1 on the system with custombuild + devecot?
What command can i use to upgrade MySQL 5.1.30.
What command ??
./update.script IMAP
