Webmail not working
verruckt
Webmail not working *fixed*
My webmail pages are showing up just fine, however noone is able to log into webmail; any of them. Here is the error I'm recieving..
ERROR (2): fsockopen() [function.fsockopen]: php_network_getaddresses: getaddrinfo failed: Name or service not known (/var/www/html/webmail/inc/class.uebimiau_mail.php:80)
Searching the forums, i came across this thread that the user described a similar problem to mine..
http://www.directadmin.com/forum/showthread.php?t=19542&highlight=login+webmail
In that thread it was suggested to edit the /etc/hosts file. I commented out the line that was in there, and added my localhost information. Here is my /etc/hosts file..
# Do not remove the following line, or various programs
# that require network functionality will fail.
#::1 localhost6.localdomain6 localhost6
127.0.0.1 localhost6 localhost6.localdomain6
123.123.123.123 my.server.hostname
my system os: CentOS5.2 i386
I would appreciate any ideas, or suggestions. Thank you.
the 127 line is wrong. Change it to:
127.0.0.1 localhost localhost
Thnx Scsi, that did it.
Just for my own notes, was there something from the install of DA or my os that may have caused that odd entry?
