circlesquare
- May 24, 2007
I recently decided to switch from using PHP CLI to CGI mode with suPHP. Here are the steps I followed to ensure everything was working. Let me know if you spot any flaws or know of a better way of doing this.
NOTE: I am continually updating this post. It is safe to assume that all posts which mention improvements/security fixes have been included where relevant if they were posted before the last time this post was edited. (See bottom of this post for timestamp)
Ok, lets get started..
suPHP doesn't allow the use of php_flag and php_value in .htaccess files, so find users with these setup and deal with them (or their sites will throw a 500 error)
Once you have dealt with those sites, suPHP should be good to go..
Edit the custombuild options file to use PHP in CGI mode
and change
to
If you need a custom config of PHP or suPHP then you can find which config files to change using:
Now we can build PHP
Ensure the new php.ini is correct.. the old one was located at /usr/local/lib/php.ini
It might be worth using custombuild to secure php some more. Using secure_php disables register_globals and adds some potentially vulnerable functions to the disable_functions list in the main php.ini file. These can be overridden on an individual basis per user if need be in their individual php.ini files
We need to reset ownership of files as suPHP won't allow access to ones owned by apache (they way the CLI version of PHP works)
Sessions will also have wrong ownership or now be corrupt so remove those
Sites which have files or directories with global write access will also cause suPHP to throw an error, therefore change all files to 644 and directories to 755
perl and cgi scripts need execute permissions though
Make sure webmail and phpMyAdmin work by resetting their ownership and permissions also
Now lets enable open_basedir per user, and create user's own tmp directories to make the server more secure. (I realize that I have done this on a per user basis rather than per domain, it should be straight forward to change if you do want it per domain)
automate creation of per user php.ini for new users (make sure the chown refers to your DirectAdmin user)
use the following shell script:
note that in the above script you may need to alter the open_basedir setting to add allowed paths (e.g. PHP's pear modules /usr/local/php5/lib/php) depending on your server setup
in order to remove the user completely we need to release the chattr +i on the php.ini config directory first (make sure the chown refers to your DirectAdmin user)
create php.ini files for current users
copy VirtualHost templates to custom directory so they are not overwritten when DirectAdmin updates
change VirtualHost containers to look for php.ini override
add this after the ErrorLog
rewrite httpd configs for current users
To make sure webmail and phpMyAdmin work, set open_basedir in the global php.ini which will apply to webapps.
find the open_basedir line and change to:
Then change the httpd.conf file to make sure the php.ini file isn't overridden by user's specific php.ini files:
find the <IfModule mod_suphp.c> section within the <Directory "/var/www/html"> block and change to:
That should be the lot, make sure Apache is restarted.
Hopefully everything is working!
Notes
If a customer wants to use cronjobs they need to add the php.ini in the cron command:
Thanks to smtalk for some troubleshooting at http://www.directadmin.com/forum/showthread.php?t=19221
Thanks to getUP for securing the php.ini file
Thanks to Dennis for the suggestion of running ./build secure_php and cron job heads up
Thanks to scooby2 for suggesting extra openbase_dir paths e.g. php's pear modules
Thanks to jlasman for spotting a typo
find /home/*/domains/*/public_html -name ".htaccess" | xargs grep "php_"
./build clean
nano options.conf
and change
php5_cli=yes
php5_cgi=no
php5_cli=no
php5_cgi=yes
./build used_configs
./build php
nano /usr/local/etc/php5/cgi/php.ini
./build secure_php
ls -l /home | grep '^d' | awk '{system("chown -R " $3 ":" $4 " /home/" $9 "/domains")}'
rm -f /tmp/sess_*
find /home/*/domains/*/public_html -type f -exec chmod 0644 {} \; -print
find /home/*/domains/*/private_html -type f -exec chmod 0644 {} \; -print
find /home/*/domains/*/public_html -type d -exec chmod 0755 {} \; -print
find /home/*/domains/*/private_html -type d -exec chmod 0755 {} \; -print
find /home/*/domains/*/public_html -name "*.pl" -exec chmod 0744 {} \; -print
find /home/*/domains/*/private_html -name "*.pl" -exec chmod 0744 {} \; -print
find /home/*/domains/*/public_html -name "*.cgi" -exec chmod 0744 {} \; -print
find /home/*/domains/*/private_html -name "*.cgi" -exec chmod 0744 {} \; -print
chown -R webapps:webapps /var/www/html
find /var/www/html -type f -exec chmod 0644 {} \; -print
find /var/www/html -type d -exec chmod 0755 {} \; -print
find /var/www/html -name "*.pl" -exec chmod 0744 {} \; -print
find /var/www/html -name "*.cgi" -exec chmod 0744 {} \; -print
touch /usr/local/directadmin/scripts/custom/user_create_post.sh
chmod 755 /usr/local/directadmin/scripts/custom/user_create_post.sh
chown diradmin:diradmin /usr/local/directadmin/scripts/custom/user_create_post.sh
nano /usr/local/directadmin/scripts/custom/user_create_post.sh
#!/bin/sh
mkdir /usr/local/directadmin/data/users/$username/php/
chown $username:$username /usr/local/directadmin/data/users/$username/php/
touch /usr/local/directadmin/data/users/$username/php/php.ini
echo "open_basedir = /home/$username/:/tmp/" >> /usr/local/directadmin/data/users/$username/php/php.ini
chown root:root /usr/local/directadmin/data/users/$username/php/php.ini
chattr +i /usr/local/directadmin/data/users/$username/php/
exit 0;
touch /usr/local/directadmin/scripts/custom/user_destroy_pre.sh
chmod 755 /usr/local/directadmin/scripts/custom/user_destroy_pre.sh
chown diradmin:diradmin /usr/local/directadmin/scripts/custom/user_destroy_pre.sh
nano /usr/local/directadmin/scripts/custom/user_destroy_pre.sh
#!/bin/sh
chattr -i /usr/local/directadmin/data/users/$username/php/
exit 0;
ls -l /home | grep '^d' | awk '{system("username="$3" /usr/local/directadmin/scripts/custom/user_create_post.sh")}'
cp /usr/local/directadmin/data/templates/virtual_host2* /usr/local/directadmin/data/templates/custom/
nano /usr/local/directadmin/data/templates/custom/virtual_host2.conf
nano /usr/local/directadmin/data/templates/custom/virtual_host2_sub.conf
nano /usr/local/directadmin/data/templates/custom/virtual_host2_secure.conf
nano /usr/local/directadmin/data/templates/custom/virtual_host2_secure_sub.conf
|*if SUPHP="1"|
SetEnv PHP_INI_SCAN_DIR /usr/local/directadmin/data/users/|USER|/php/
|*endif|
open_basedir = /var/www/html/:/tmp/
nano /etc/httpd/conf/httpd.conf
suPHP_Engine On
suPHP_UserGroup webapps webapps
</IfModule>
service httpd restart
Notes
/usr/local/bin/php -c /usr/local/directadmin/data/users/accountname/php/php.ini /home/accountname/domains/domainname/public_html/filetocron.php
