Is there a way to change a license IP address in control panel?
darkus
I purchased a license last night but I entered in the incorrect IP address when I purchased the license (like an idiot!) and I need to change the IP to the correct one, but I don't see any option anywhere to change the IP. Does anyone know how I can do this? I've sent an email to the technical support email address but i'm not sure if they are the ones to contact about this or the sales or billing department.
Thanks for any help, this server needs to go up asap :)
Did you put the wrong ip on the server or for the license or both?
Well in the directadmin client login area is where I entered the incorrect IP address, so I won't be able to install DA onto my server until I can correct that IP address
Does anyone know if I can change it myself? its been a few hours now and they are probably all off work right now but I need my server up asap....
You need to be patient no you cannot do it yourself.
