Mysql update gone wrong
mimic
Utrecht, The Netherlands
I tried to upgrade mysql from 5.0 to 5.1, but got an error.
So i removed 5.1 files and downloaded 5.0 again:
tesla:/usr/local/directadmin/custombuild# ./build mysql
--14:32:18-- http://files.directadmin.com/services/all/mysql/debian/mysql-5.0.67-linux-i686.tar.gz
=> `mysql-5.0.67-linux-i686.tar.gz'
Resolving files.directadmin.com... 72.35.85.222
Connecting to files.directadmin.com[72.35.85.222]:80... connected.
Length: 28,160,997 [application/x-gzip]
100%[=======================================================================================>] 28,160,997 261.37K/s ETA 00:00
14:34:04 (258.74 KB/s) - `mysql-5.0.67-linux-i686.tar.gz' saved [28160997/28160997]
Stopping mysqld ...
Stopping mysqld: [ FAILED ]
/etc/init.d/mysqld: line 9: cd: /usr/local/bin/mysql: Not a directory
Starting mysqld: [ OK ]
Giving mysqld a few seconds to start up...
Looking for 'mysql' in: /usr/local/mysql-5.0.67-linux-i686/bin/mysql
Looking for 'mysqlcheck' in: /usr/local/mysql-5.0.67-linux-i686/bin/mysqlcheck
This installation of MySQL is already upgraded to 5.0.67, use --force if you still need to run mysql_upgrade
/usr/local/mysql/bin/mysqlcheck: unknown option '--fix-db-names'
Restarting MySQL.
Stopping mysqld: [ OK ]
It is recommended to do "./build php n" after MySQL update.
But the service stays offline.
090217 20:36:23 mysqld started
090217 20:36:23 [Warning] option 'max_join_size': unsigned value 18446744073709551615 adjusted to 4294967295
090217 20:36:28 InnoDB: Started; log sequence number 0 11612889
090217 20:36:28 [Note] /usr/local/mysql/bin/mysqld: ready for connections.
Version: '5.0.67' socket: '/tmp/mysql.sock' port: 3306 Source distribution
090217 20:36:28 [Note] /usr/local/mysql/bin/mysqld: Normal shutdown
090217 20:36:28 InnoDB: Starting shutdown...
090217 20:36:32 InnoDB: Shutdown completed; log sequence number 0 11612889
090217 20:36:32 [Note] /usr/local/mysql/bin/mysqld: Shutdown complete
090217 20:36:32 mysqld ended
from the error log in /home/mysql/
Maybe something is jacked up try reinstalling mysql. Remove the mysql rpm that you are not using.
Thank you for your awnser.
I reinstalled MySQL numerous of times. And I did remove all the other debs.
It keeps complaining that some directories are not present. It might be broken symlinks?
I'm using Debian 4.
I would backup the database directory somewhere and completely remove mysql then reinstall it via custombuild.
I had it installed via Custombuild, always had.
When i tried this afternoon to upgrade it from 5 to 5.1, it crashed, and never came back up..
..until now, it seems to be running. The websites are getting databse results.
But this is far from good.
try my.cnf
Just in case someone else has this issue, you should look at the settings in the file:
/etc/my.cnf
The system might have had different paths for the data and/or log and/or lock files, and now it's unable to use them.
Bare in mind: moving a MySQL from one path to the other, must be done strictly by the book. Especially if you have InnoDB tables.
Dotan
