Exim segfaults with lenny
paulus
Try to look at google, but didnt find anything.
Since last wednesday, when I updated my server to debian lenny, I receive every 15 minutes or so segfaults from lenny:
From my syslog:
Feb 27 22:40:21 sandy kernel: [196165.062101] exim[23542]: segfault at 1820160a ip 1820160a sp bfa7c09c error 4
Feb 27 22:40:21 sandy kernel: [196165.062101] exim[23543]: segfault at 1820160a ip 1820160a sp bfa7c0a0 error 4
Feb 27 22:40:21 sandy kernel: [196165.062101] exim[23544]: segfault at 1820160a ip 1820160a sp bfa7c09c error 4
Feb 27 22:40:21 sandy kernel: [196165.062340] exim[23545]: segfault at 1820160a ip 1820160a sp bfa7c0a0 error 4
Feb 27 22:40:21 sandy kernel: [196165.066100] exim[23546]: segfault at 1820160a ip 1820160a sp bfa7c09c error 4
Feb 27 22:40:21 sandy kernel: [196165.066100] exim[23547]: segfault at 1820160a ip 1820160a sp bfa7c0a0 error 4
Feb 27 22:40:21 sandy kernel: [196165.066100] exim[23548]: segfault at 1820160a ip 1820160a sp bfa7c0a0 error 4
Feb 27 22:40:21 sandy kernel: [196165.066100] exim[23549]: segfault at 1820160a ip 1820160a sp bfa7c0a0 error 4
Feb 27 22:40:21 sandy kernel: [196165.070292] exim[23550]: segfault at 1820160a ip 1820160a sp bfa7c09c error 4
Feb 27 22:40:21 sandy kernel: [196165.071187] exim[23551]: segfault at 1820160a ip 1820160a sp bfa7c09c error 4
From my mainlog:
2009-02-27 22:40:21 queue run: process 23542 crashed with signal 11 while delivering 1Ld5sg-0005L6-Iz
2009-02-27 22:40:21 queue run: process 23543 crashed with signal 11 while delivering 1Ld6x0-0007UF-74
2009-02-27 22:40:21 queue run: process 23544 crashed with signal 11 while delivering 1LchvU-0000tN-Q5
2009-02-27 22:40:21 queue run: process 23545 crashed with signal 11 while delivering 1LcjkG-0004N1-Pt
2009-02-27 22:40:21 queue run: process 23546 crashed with signal 11 while delivering 1LchwC-0000ui-T2
2009-02-27 22:40:21 queue run: process 23547 crashed with signal 11 while delivering 1Ld3RV-0000Z3-4o
2009-02-27 22:40:21 queue run: process 23548 crashed with signal 11 while delivering 1LcmQ0-0001BL-6S
2009-02-27 22:40:21 queue run: process 23549 crashed with signal 11 while delivering 1LcvxM-0003QR-LY
2009-02-27 22:40:21 queue run: process 23550 crashed with signal 11 while delivering 1Ld9SL-00046L-93
2009-02-27 22:40:21 queue run: process 23551 crashed with signal 11 while delivering 1LclQB-0007cF-An
2009-02-27 22:40:21 queue run: process 23552 crashed with signal 11 while delivering 1LcxcV-0006Lk-Ru
2009-02-27 22:40:21 queue run: process 23553 crashed with signal 11 while delivering 1Ld78X-0007qX-LC
2009-02-27 22:40:21 queue run: process 23554 crashed with signal 11 while delivering 1Lcky6-0006jM-7D
2009-02-27 22:40:21 queue run: process 23555 crashed with signal 11 while delivering 1LcnPq-00039U-0I
2009-02-27 22:40:21 queue run: process 23556 crashed with signal 11 while delivering 1Ld3T2-0000aM-50
2009-02-27 22:40:21 queue run: process 23557 crashed with signal 11 while delivering 1Lci9n-0001Ks-W4
2009-02-27 22:40:21 queue run: process 23558 crashed with signal 11 while delivering 1Lcqa9-0002Ir-B0
2009-02-27 22:40:21 queue run: process 23559 crashed with signal 11 while delivering 1Ld1Ed-0004cV-H4
2009-02-27 22:40:21 queue run: process 23560 crashed with signal 11 while delivering 1Lci9p-0001Kt-O8
2009-02-27 22:40:21 queue run: process 23561 crashed with signal 11 while delivering 1LclUt-0007la-Fs
2009-02-27 22:40:21 queue run: process 23562 crashed with signal 11 while delivering 1LcodC-0005W9-5h
2009-02-27 22:40:21 queue run: process 23563 crashed with signal 11 while delivering 1Lcx3K-0005Lv-Ec
2009-02-27 22:40:21 queue run: process 23564 crashed with signal 11 while delivering 1LcnHA-0002r8-KG
2009-02-27 22:40:21 queue run: process 23565 crashed with signal 11 while delivering 1Lcmqq-00020K-TH
2009-02-27 22:40:21 queue run: process 23566 crashed with signal 11 while delivering 1LcoEq-0004kw-M0
2009-02-27 22:40:21 queue run: process 23567 crashed with signal 11 while delivering 1Lcm3F-0000QP-RO
2009-02-27 22:40:21 queue run: process 23568 crashed with signal 11 while delivering 1Lcy5x-0007Bm-GV
2009-02-27 22:40:21 queue run: process 23569 crashed with signal 11 while delivering 1Ld4LR-0002JZ-Ru
2009-02-27 22:40:21 queue run: process 23570 crashed with signal 11 while delivering 1Ld29u-0006PZ-OC
2009-02-27 22:40:21 queue run: process 23571 crashed with signal 11 while delivering 1LcnGm-0002qV-KI
2009-02-27 22:40:21 queue run: process 23573 crashed with signal 11 while delivering 1Lci9d-0001Kq-Os
2009-02-27 22:40:21 queue run: process 23574 crashed with signal 11 while delivering 1LcxJv-0005mQ-Ds
2009-02-27 22:40:21 queue run: process 23575 crashed with signal 11 while delivering 1Lcxxd-0006xg-DH
2009-02-27 22:40:21 queue run: process 23576 crashed with signal 11 while delivering 1Lcspc-0006Nb-Rg
2009-02-27 22:40:21 queue run: process 23577 crashed with signal 11 while delivering 1Lcfvg-0005Vi-Lp
2009-02-27 22:40:21 queue run: process 23578 crashed with signal 11 while delivering 1Ld5DA-00042Y-38
2009-02-27 22:40:21 queue run: process 23579 crashed with signal 11 while delivering 1LcizD-0002ww-BZ
2009-02-27 22:40:21 queue run: process 23580 crashed with signal 11 while delivering 1Ld0Lk-0002wK-M2
2009-02-27 22:40:21 queue run: process 23581 crashed with signal 11 while delivering 1Ld9lP-0004ji-AJ
2009-02-27 22:40:21 queue run: process 23582 crashed with signal 11 while delivering 1Ld4jL-000368-GV
2009-02-27 22:40:21 queue run: process 23583 crashed with signal 11 while delivering 1LcyA6-0007Jd-JK
2009-02-27 22:40:21 queue run: process 23584 crashed with signal 11 while delivering 1LcxYe-0006E5-NC
2009-02-27 22:40:21 queue run: process 23585 crashed with signal 11 while delivering 1LciGs-0001Y1-31
2009-02-27 22:40:21 queue run: process 23586 crashed with signal 11 while delivering 1Lck28-0004wH-E1
2009-02-27 22:40:21 queue run: process 23587 crashed with signal 11 while delivering 1Ld4WB-0002ht-4Z
2009-02-27 22:40:21 queue run: process 23588 crashed with signal 11 while delivering 1Ld19R-0004TN-W8
2009-02-27 22:40:21 queue run: process 23589 crashed with signal 11 while delivering 1Ld2aB-0007KZ-QA
2009-02-27 22:40:21 queue run: process 23590 crashed with signal 11 while delivering 1Ld4Y2-0002k9-U3
2009-02-27 22:40:21 queue run: process 23591 crashed with signal 11 while delivering 1Lcywh-0000NI-ME
2009-02-27 22:40:21 queue run: process 23592 crashed with signal 11 while delivering 1LcmAE-0000eJ-Er
2009-02-27 22:40:21 queue run: process 23593 crashed with signal 11 while delivering 1LcmhK-0001gz-30
2009-02-27 22:40:21 queue run: process 23595 crashed with signal 11 while delivering 1LchPq-0008MA-Ai
2009-02-27 22:40:21 queue run: process 23596 crashed with signal 11 while delivering 1Lcmy1-0002Ed-6n
2009-02-27 22:40:21 queue run: process 23597 crashed with signal 11 while delivering 1Lcx1T-0005JA-2O
I discovered 1 email in my mailqueue that at least triggers it:
(Removed emailaddress in TO) headers:
1Ld6x0-0007UF-74-H
mail 8 8
<[email protected]>
1235757402 0
-helo_name 20158181037.user.veloxzone.com.br
-host_address 201.58.181.37.4102
-host_name 20158181037.user.veloxzone.com.br
-interface_address 89.18.168.236.25
-received_protocol esmtp
-body_linecount 3
-max_received_linelength 137
-deliver_firsttime
XX
1
[email protected]
241P Received: from 20158181037.user.veloxzone.com.br ([201.58.181.37])
	by sandy.hosthuis.nl with esmtp (Exim 4.69)
	(envelope-from <[email protected]>)
	id 1Ld6x0-0007UF-74
	for [email protected]; Fri, 27 Feb 2009 18:56:43 +0100
038  Date: Fri, 27 Feb 2009 14:56:42 -0300
045F From: =?koi8-r?B?9MHSzc8=?= <[email protected]>
031* Return-Path: <[email protected]>
023  X-Priority: 3 (Normal)
057I Message-ID: <[email protected]>
027T To: [email protected]
076  In-Reply-To: <[email protected]>
138  References: <[email protected]> <[email protected]>
059  Subject: =?koi8-r?B?1MXCxSDF3cUgztXWzs8gzc+jINfJxMXPPw==?=
018  MIME-Version: 1.0
041  Content-Type: text/plain; charset=koi8-r
032  Content-Transfer-Encoding: 8bit
I dont see anything special on this. Does anyone have a idea what the solution can be? Untill now it looks like it only happens on spam, but maybe it also will happen on normal mail later.
Thanks.
I've the same problem with lenny + da + exim 4.67
In mail queue i receive duplicate (and more more and more) of the same message. Not spam, true email and notification sended weeks ago and that return every 5 minutes in the queue. Some accounts receive the same mail 50-100... times.
Please help... it seems to be a bug
Same problem for me. Multiple modules fail after upgrading to Lenny:
- ISO8859-1.so
- libGB.so
- libKSC.so
The mail queue is rising to 1000 not processed mails a day, luckily it's only 99% spam. The mails failing always have an html body and some multipart/alternative content. Headers and body on request :)
Note that we do not yet support Debian 5.0.. so I wouldn't recommend upgrading to it since none of the binaries are setup for it.
For the case of any segfaulting binaries (like exim in this case), they'd have to be recompiled. This is the guide for that:
http://help.directadmin.com/item.php?id=125
but as mentioned above, we've not yet looked at debian 5.0, so can't comment on what will/won't work regarding anything debian 5 related..
it looks like that did work. Its currently delivering all mails. Untill now I didnt find any other problems with running lenny.
Will the support to Lenny be available in the near future? Debian will stop supporting Debian Etch this month... I had to updgrade a customer's server to Lenny and now the server suffers the same problems reported here..
I will compile exim but I'm worried for this "lack" of support :(
That's an old old post. We've support it for quite a while now.
Check the install requirements page to see the list of OS's:
http://www.directadmin.com/install.html
64-bit Debian 5 is almost done testing (no issues reported for quite some time), so you can use either 32-bit or 64-bit with Debian 5.
the problem suddenly came back again. I tried to recompile exim to 4.73 but the problem yet persists:
[13236258.603830] exim[11082]: segfault at f8f ip 080b1ce7 sp bffbaa90 error 6 in exim[8048000+cc000]
usually it helps to recompile exim, i dunno why it didnt help now.
2.6.26-2-686 #1 SMP Wed Feb 10 08:59:21 UTC 2010 i686 GNU/Linux
lenny 5 32bit
Hi.
Try to download da_exim-4.72.deb package and install it
# wget http://files.directadmin.com/services/debian_5.0/da_exim-4.72.deb
# dpkg -i ./da_exim-4.72.deb
Maybe you will need to install few dependences (libperl5.10 or db4)
Hope this help.
Also, check your binary to make sure the compile you did was actually installed, eg:
cd /usr/sbin
ls -la exim*
./exim -bV
check the "built" date to ensure it's when you compiled it. Running a "make install" will create the exim-4.73-1, where the 1 can change if there are previous instances of the binary, so take special note of it during the last steps of the compile/install.
i tried to recompile again, double checked everything, updated lenny, new exim is running but still same error.
Exim version 4.73 #2 built 18-Jan-2011 16:51:28
Copyright (c) University of Cambridge, 1995 - 2007
Berkeley DB: Berkeley DB 4.6.21: (September 27, 2007)
Support for: crypteq IPv6 Perl OpenSSL move_frozen_messages Content_Scanning DKIM Old_Demime
Lookups: lsearch wildlsearch nwildlsearch iplsearch cdb dbm dbmnz
Authenticators: cram_md5 plaintext
Routers: accept dnslookup ipliteral manualroute queryprogram redirect
Transports: appendfile/maildir/mailstore/mbx autoreply lmtp pipe smtp
Size of off_t: 8
OpenSSL compile-time version: OpenSSL 0.9.8g 19 Oct 2007
OpenSSL runtime version: OpenSSL 0.9.8g 19 Oct 2007
Configuration file is /etc/exim.conf
Hi.
Hope this help.
downgraded to 4.72 now working!
thanks!
