CReate innodb database with api
depixelfabriek
Hi all,
I would like to know if it possible to create (or alter) a (mysql) database using the innoDB storage engine instead of the (default) MyISAM engine (using the direct admin API).
Maybe there is a other way to change or create these storage engine setting, for example using some php scripting, i am just looking for an solution, so of course i am open for alternatives..
Thanks anyway,
Sebastian
Does it mean, that directadmin doesn't support InnoDB?
I mean "Create new Database", "Check", "Repair" and "Optimize" functions via Directadmin.
P.S. It's not a problem to re-compile MySQL with InnoDB for me.
DirectAdmin does not have anything to do with mysql.
I mean "Check", "Repair" and "Optimize" functions via Directadmin.
DirectAdmin does not perform these functions at all regardless of what the storage engine is, MyISAM or InnoDB.
DirectAdmin does create the database but this has nothing to do with storage engines for individual tables since DA does not create the tables.
Ok, I will test it myself. I've got reinstalled mysql from sources with InnoDB
That's seems to me working fine. At least no error messages have occured while/after checking and optimizing InnoDB tables in the selected database.
Repair failed with message:
The storage engine for the table doesn't support repair
