Michael.Terence
- Feb 15, 2009
Strange issue...
One of my clients uses an RSS sidebar widget to display text adds on her wordpress site. The RSS feed is located here:http://ss.mysavings.com/rss.asp?pid=60
The feed includes URLs like this: http://ss.mysavings.com/offer-redirect.asp?oid=160&pid=60 (note the ampersand) - after moving her to my new DirectAdmin powered server, the URLs are showing up without the ampersand: http://ss.mysavings.com/offer-redirect.asp?oid=160pid=60
As some of you will quickly notice, I am running litespeed - I have tested her site with the custombuild apache/php install provided by the DirectAdmin installer and that does the same thing.
My php configure line is:
What's stranger still, is that on my previous Debian server (not a DA server) this worked fine, same php config line, same php.ini, same litespeed config.
I don't want to make this a litespeed issue, because it's not. It's broken in apache too.
--enable-shmop --enable-track-vars --enable-sysvsem --enable-sysvshm --enable-bcmath --enable-calendar --with-openssl --enable-exif --enable-ftp --enable-gd-native-ttf --enable-libxml --enable-mbstring --enable-pdo --enable-soap --enable-sockets --enable-zip --with-bz2 --with-curl --with-curlwrappers --with-freetype --with-gd --with-gettext --with-imap --with-imap-ssl --with-jpeg-dir=/opt --with-png-dir=/opt --with-libxml --with-mcrypt --with-mhash --with-mysql-sock=/var/lib/mysql/mysql.sock --with-mysql --with-mysqli --with-pdo-mysql --with-sqlite --with-pdo-sqlite --with-pic --with-ttf --with-zpm --with-xsl --with-zlib --with-snmp --with-imagick --with-iconv --with-zip --with-curl-ssl --with-xpm-dir=/opt --with-kerberos --enable-magic-quotes
