Suspicious process running under user mysql
shanti
Wien / Vienna - Austria
lfd is annoying me with constant reports about suspicious MYSQL- process
Executable:
/usr/sbin/mysqld\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00 (deleted)
ps
3045 ? S 0:00 /bin/sh /usr/bin/mysqld_safe --datadir=/var/lib/mysql --pid-file=/var/lib/mysql/princess.pid
3103 ? Sl 0:00 \_ /usr/sbin/mysqld --basedir=/ --datadir=/var/lib/mysql --user=mysql --log-error=/var/lib/mysql/princess
i already added
exe:/usr/sbin/mysqld
exe:/usr/bin/mysqld_safe
to /etc/cfs/cfs.pignore (also restarting the lfd/csf services) but this mail keeps bouncing up
DA-version is 1.33.3, really recently setup .. can please someone give me a hint what runs wrong here ?
thank you and best regards
-c-
ps
i already added
-c-
i have the same problem here :(
restart the process like its written in the doku, get new PID
The file system shows this process is running an executable file that has been deleted. This typically happens when the original file has been replaced by a new file when the application is updated. To prevent this being reported again, restart the process that runs this excecutable file. See csf.conf and the PT_DELETED text for more information about the security implications of processes running deleted executable files.
I'm using the config (csf.pignore) below and everything works as it should.
exe:/usr/sbin/pure-ftpd
exe:/usr/local/apache/bin/httpd
exe:/usr/sbin/sshd
exe:/usr/sbin/proftpd
exe:/usr/sbin/httpd
exe:/usr/local/php4/bin/php-cgi
exe:/usr/local/php5/bin/php-cgi
exe:/usr/local/php6/bin/php-cgi
exe:/usr/libexec/dovecot/pop3
exe:/usr/libexec/dovecot/pop3-login
exe:/usr/libexec/dovecot/dovecot-auth
exe:/usr/libexec/dovecot/imap
exe:/usr/libexec/dovecot/imap-login
exe:/usr/lib/courier-imap/bin/pop3d
exe:/usr/lib/courier-imap/bin/imapd
exe:/usr/local/directadmin/directadmin
exe:/usr/local/urchin/bin/urchinwebd
exe:/usr/bin/spamc
exe:/usr/local/apache1/bin/httpd
exe:/usr/local/apache2/bin/httpd
exe:/usr/sbin/httpd
exe:/usr/sbin/named
exe:/usr/sbin/vm-pop3d
exe:/bin/sh
exe:/bin/bash
exe:/usr/sbin/sendmail
exe:/sbin/quotaoff
exe:/bin/tar
exe:/sbin/quotaon
exe:/usr/local/directadmin/dataskq
exe:/usr/sbin/snmpd
exe:/usr/sbin/ntpd
exe:/usr/sbin/exim
exe:/usr/sbin/atd
exe:/usr/bin/webalizer
exe:/usr/bin/perl
exe:/usr/local/directadmin/plugins/Stats_Control/awstats/cgi-bin/awstats.pl
exe:/usr/sbin/nrpe
exe:/usr/sbin/bacula-fd
exe:/usr/local/psa/admin/bin/httpsd
exe:/usr/bin/imapd
exe:/usr/sbin/crond
user:root
user:named
user:apache
user:ntp
user:dbus
user:smmsp
user:postfix
user:www-data
user:dovecot
user:daemon
user:sync
user:admin
user:nobody
user:rpm
user:diradmin
user:mysql
user:webapps
user:majordomo
user:mail
user:exim
user:sshd
user:webalizer
user:mgmt
user:qmaill
user:qmailr
user:qmailq
user:mailman
user:qmails
user:qmaild
user:haldaemon
* Note: Restart CSF/LDF after changing files
