ozgurerdogan
- Apr 20, 2008
When I tail error.log, I see:
tail -f error_log
[Fri May 08 22:05:35 2009] [warn] Init: SSL server IP/port conflict: www.domain.com.tr:443 (/usr/local/directadmin/data/users/admin/httpd.conf:54) vs. www.subdomain.domain.com:443 (/usr/local/directadmin/data/users/admin/httpd.conf:272)[Fri May 08 22:05:35 2009] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.subdomain.domain.com:443 (/usr/local/directadmin/data/users/admin/httpd.conf:272)
[Fri May 08 22:05:35 2009] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Fri May 08 22:05:35 2009] [notice] Apache/2.2.11 (Unix) mod_ssl/2.2.11 OpenSSL/0.9.8b DAV/2 PHP/5.2.9 configured -- resuming normal operations
www.domain.com.tr is the domain that is running on ssl. There is kind of issue with ssl domain and its subdomains.
How can I fix this?
Thank you
tail -f error_log
How can I fix this?
Thank you
